Old 05-28-2016, 02:02 PM   #11
Any word about what was wrong with the lifter? If your battery is low or the winch stops are improperly adjusted, you could have that problem.
kraftengr is offline   Reply With Quote
Old 05-29-2016, 07:44 AM   #12
It wasn't limits because it went up around 90% them would not go up or down. The battery was fine because the dolly jack worked. Also, we hooked up to shore power and saw no change. The service department said it was the controller board for the lifter that burned out. They replaced the unit and everything is fine now.
sctheis is offline   Reply With Quote
Old 05-29-2016, 08:12 AM   #13
OK- I was curious because we had a problem with our lift stopping at 90%, and even connecting to local power would not overcome the weak / dead battery while the tongue Jack worked fine. In our case, replacing the battery solved everything. Thanks for the reply!
Old 05-29-2016, 08:55 AM   #14
You can set the lift limits and the lowering limits of the winch.
kinma13 is offline   Reply With Quote
roo, roof
