06-09-2011, 10:24 AM
Lighting pilot propane refrigerator
I find it very frustrating trying to see if the pilot to the propane refrigerator has lit.
This is especially true in bright light. The shield hides the flame and the hole to look trough is not in front of the flame. I have tried wearing dark sun glasses, and even putting something over me to make it darker, but that’s not much help. ( Not to mention how goofy I must look )
I think that often it lights on the first attempt but I can’t tell. When it’s dark I can see the light and know that it almost always starts on the first attempt, so long as the line has been purged of air.
I bet many of you have solved this problem and would love to hear what you do.
06-09-2011, 10:30 AM
I put my ear up close to the vent and listen. You can hear the clicking, and then when the fridge lights, there is a slight "roar".
08-28-2011, 10:14 PM
Mostly Harmless
Try this, save the cardboard from a roll of paper towels and look through it at your pilot orifice. Unless you wear bifocals it should work.
It's never too late to have a happy childhood!
Lee, WU0V, and Courtenay, N0ZDT
2011 Rockwood A128
2000 Silverado 1500 pickup
60W solar system
2000W inverter generator
08-28-2011, 11:15 PM
Thanks I will give that a try...
08-29-2011, 01:49 AM
Usually if it doesnt light the check light comes on
2008 8296SS Rockwood Signature Ultralite
2002 Silverado 2500HD extended cab
08-29-2011, 10:06 AM
Mostly Harmless
I've not heard about a check light. I don't think my unit has one. Would it be inside the camper or in the fridge's wiring and controls area under the removable panels outside?
2011 Rockwood A128
60W solar system
08-29-2011, 10:18 AM
X2
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
08-29-2011, 10:28 AM
Most check lights are above the freezer door, next to the toggle switch that controls the gas or electric selection. If the fridge fails to light the bulb will illuminate.
08-29-2011, 12:07 PM
Mostly Harmless
Ah, there's the difference, then. My small folddown has no freezer on its refrigerator, and no indicator lights. You most likely have a much more comfortable larger unit.
2011 Rockwood A128
60W solar system
08-29-2011, 08:05 PM
Lottery Non-Winner
Still, freezer or not, you should have some sort of indicator. Having said that, the ear to the burner works well, and the cardboard tube is a slick trick that should serve the purpose.
2011 Georgetown 337
2009 HD FLHTCU
2007 HD FXSTC
08-29-2011, 08:39 PM
I remember the same problem back in my pop up days.I could tell it was running after ignition because in a couple minutes the "flue" would start getting warm from the pilot light!
Kevin and Joanne
06 wildwood 27le fbss
08 dodge ram 4x4 5.7 quad cab
07 kawasaki brute force 650i
08-30-2011, 09:58 AM
I wish it just had a auto pilot thing like the furnace, or if they would change the design so that you can see the pilot better. And why should you have to go out side to do this? Guess we will have to do the best we can.
Thanks for all of your advice.
09-05-2011, 07:50 PM
I'm gonna try the paper towel roll trick next trip.
I also have a hard time seeing the pilot light and at most camp grounds there is too much noise on set up day to hear any "roar". I also check the metal heat shield around the burner to see if it is getting warm. Warm = lit.
09-05-2011, 07:52 PM
A make and model number would be very helpful here.
Very few refrigerators have pilot lights these days.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
09-05-2011, 08:05 PM
Mine is a Dometic in a 2011 228d. It has a clicker like a gas grill to light the burner when on L.P. I think they mean burner and not pilot light.
09-05-2011, 08:09 PM
Seriously?
You have a fridge with a clicker lighter?
Are you SURE you are not talking about a range top?
09-05-2011, 08:26 PM
Nope, welcome to the world of pop-ups. Primitive, but fun.
Remember, we're tents with wheels, but we sure do love them.
09-05-2011, 08:31 PM
(Kim)
To add another question to this thread - has anyone had the fridge pilot light go out while towing?
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
DH (Alan), DD (Madison) and Zoey the lab,
DOH!
I stand corrected!
09-05-2011, 08:44 PM
To Labzy, yes ours went out on our last trip, don't think I will leave it lit while traveling again.
To Herk,
Yup, for $13,000 you get a furnace that lights automatically, a hot water heater you need to light the pilot with a lighter, a fridge with a clicker and a three burner range you light with a lighter, no clicker, those are on the hi end models. (lol)
