Old 05-29-2018, 11:02 PM   #1
Angry Location of water pump switch Rockwood 2010
Just recently purchased a Forest River Rockwood 2010 HW256. Where is the switch for the water pump? Went camping Memorial Day weekend and was not able to pump water into the unit to wash dishes or take a shower. I am also confused about when the pump is to be used. Is it only for pumping water from the holding tank for potable water? Where is opening to drain water from the holding tank?
bhowcroft is offline   Reply With Quote
Old 05-29-2018, 11:16 PM   #2
MontyPP's Avatar
I'm not an owner, I have an A-Frame,. But I would look for a switch somewhere near the sink, it may be in a cabinet. Water in the freshwater tank then turn on the pump. You also need water in the hot water heater before using it. The freshwater tank drain is normally on the tank, on the same side as the fill inlet. The "City Water" connection does not fill the freshwater tank.
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
2016 Nissan Frontier Crew Cab
Flagstaff T21TBHW
MontyPP is offline   Reply With Quote
Old 05-30-2018, 08:18 AM   #3
I have a Mac but my pump is under an access panel under the sink. Be aware there is a small filter on that line that needs to be winterized. If you are hooked to a water supply no pump needed. My pump switch is near the floor by the sink. To drain the tank there is a release valve under the camper on the tank. Keep your weight down and it empty unless needed
agsmth is offline   Reply With Quote
Old 05-31-2018, 04:25 PM   #4
I have a different model rockwood tent
My water pump switch is beside the main fuse/breaker panel
To drain it, the valve is probably outside near the water tank outlet.
Milk_Man is offline   Reply With Quote
Old 06-02-2018, 05:26 PM   #5
Water Pump Switch 2010 Rockwood Popup
Than you for your answer.
Old 06-10-2018, 08:13 PM   #6
The switch is located at the dining area on the seat that has its back to the sink, You use that pump when you are not hooked up to a external water supply , it will pump from your fresh water tank as long as it has water in it. If you wish to drain your fresh water tank there is a valve on the bottom of the tank, same side as your hook ups, you will have to nearly craw under to see it because its behind a metal guard. Hope this helps you some.
TimothyG is offline   Reply With Quote
cat, location, pump, rockwood, switch, water, water pump
