Old 06-30-2019, 11:04 AM   #1
Locks on storage box 2018 Rockwood 1910ESP
The locks on the storage box will not turn with key. Yes, it is the correct key. Used graphite, still wont turn. Even the small door lock is nearly impossible to use. Any suggestions?Click image for larger version
ID:	208556Click image for larger version
jpennington is offline   Reply With Quote
Old 06-30-2019, 11:22 AM   #2
bob213's Avatar
Does the key turn in the cylinder if the door is open?
You can avoid reality, but you cannot avoid the consequences of avoiding reality – Ayn Rand
bob213 is offline   Reply With Quote
Old 06-30-2019, 12:22 PM   #3
bundy71's Avatar
I used a little wd40 on mine.
bundy71 is offline   Reply With Quote
Old 06-30-2019, 01:40 PM   #4
On mine I used WD40 also but I have to push in on the door by the lock just a touch and opens and closes easily then.
2021 Apex Nano 191RBS OFF GRID
2017 Chevy Colorado Z71 4x4 3.6 L
backpacker3 is offline   Reply With Quote
Old 06-30-2019, 01:53 PM   #5
bundy71's Avatar
I did that too. I forgot, until I read your reply.
Old 06-30-2019, 06:57 PM   #6
No. Not at all.
Old 06-30-2019, 08:02 PM   #7
bob213's Avatar
Originally Posted by jpennington View Post
No. Not at all.
Then you have a bigger problem than WD 40 will solve. Either your key is bad or a tumbler has dropped. Hard to believe it's the tumbler in more than one lock. Ask another RV'er to use their key (most of us have a CH750) and see if it works.
Old 07-01-2019, 01:08 PM   #8
Usually...
Usually CH751. Buy spares on Amazon or eBay.
These are a pretty simple lock.
First, see if the key will turn while pushing in HARD on the door.
Then, see if the key will turn while pulling out HARD on the door.
If either of these works, the frame or door is slightly warped. Nothing to fix. Just remember to pull or push as appropriate.
If the lock still doesn't work, get a lock-pick set from Amazon or eBay. Use the L-shaped tool at the outer edge of the opening to try to turn the cylinder. At the same time, use one of the pick tools at the other end of the opening to tickle the tumblers. On this simple lock, even an amateur should be able to open it in five minutes.
Once the door is opened, unscrew the tongue from the lock, then unscrew the lock. Buy a replacement from Amazon, eBay, or an RV supply. You may want to transfer the old tongue to the new lock after installing it.
Larry
Larry-NC is offline   Reply With Quote
Old 07-01-2019, 01:25 PM   #9
Larry
Thank you so much. I will check it tonight.
Old 07-01-2019, 02:04 PM   #10
Freetyme's Avatar
I got tired of the same problem. Finally replaced with this type
Freetyme is offline   Reply With Quote
Old 07-01-2019, 02:12 PM   #11
Semperfi24's Avatar
I swapped out all of the ones on our trailer with a combicam lock. Using a 3 digit combination (you set the combo of your choice). Then you never have to worry about having your keys on you all the time. Because without fail, when you need to get into a storage door, you left the keys inside, or on the picnic table, or in the truck, etc. I dont believe this is the exact ones we purchased, but the cams are similar to the ones below. Dont recall the length of the shaft, but you can measure to get the length you need. We also bought the plastic covers to keep dust and moisture out
https://www.amazon.com/Combi-Cam-785.../dp/B000W7GC5S
_________________________
2023 GMC Sierra 3500 Denali
2020 Cherokee Arctic Wolf 287BH
Semperfi24 is offline   Reply With Quote
Old 07-01-2019, 02:43 PM   #12
Originally Posted by Freetyme View Post
I got tired of the same problem. Finally replaced with this typeAttachment 208687
Where did you purchase these?
Old 07-01-2019, 03:17 PM   #13
Bob414
Your lock is broke. I assume the same key fits all the locks on your camper. Normally having to replace only one lock means adding an additional key to your keyring. But as was stated earlier, these are cheap locks. Almost anybody, who knows how these locks work, can pick them with a paperclip and a small screwdriver in less than a minute.
If you can get a replacement lock with the same type key. Meaning the key fits in the lock (does not need to turn), you can use the number stamped on the key or the cylinder of the old lock. To re-pen the new lock to the old key. About any locksmith can do that.
2014 Flagstaff 206LTD
2008 Nissan Armada LE 4X4 TV
Amateur Astronomer Golf
Retired Electrical Engineer
Bob414 is offline   Reply With Quote
Old 07-01-2019, 03:44 PM   #14
I had the same problem and found that I had the key upside down. It actually went into the slot but would not turn. Boy did I feel stupid.
jayandmarji is offline   Reply With Quote
Old 07-01-2019, 05:56 PM   #15
Freetyme's Avatar
This pic is just an example. I bought a 4 pack on Amazon. Just search for cam locks, many supplier's.
Old 07-01-2019, 06:10 PM   #16
Get rid of the locks with the CH751 key so that everybody in the campground can't open your door. You can buy locks that use the same key as your entry door so you will only have to have one key.
Cam Lock CH751 Security Upgrade
babock is offline   Reply With Quote
Old 07-02-2019, 07:46 AM   #17
Thank you. I will replace the locks.
lock, rockwood, storage
