Looking for a little help .. Rockwood Premier
I have recently become the proud owner of a 2001 Rockwood Premier model # 3-PRT234SD and am wondering (really hoping ) someone here has either the exact same year, or perhaps one close to the age of mine that still may have their owner's manuals. I have searched the web, high and low with no luck.
I have several questions regarding this pup and could use a little help if someone has one.
question #1: my pup is missing the wire that shows when you have raised the roof to the proper height. If I raise it until I have reached it's limit, the 2 extra corner stabilizers aren't long enough to tuck under the top and will fall out. If I lower it down to the point where these stabilizers actually fit tight, the canvas and plastic window covers have wrinkles. So.. what would be the recommended height I should set the top ?
question #2 ( see above ) When I have the top cranked up so that the 2 extra corner stabilizers stay in place it seems as though the top sways a bit, is this normal?
question #3 My pup has a built in porta potti and a shower.. The shower drains out on the ground. There is nothing attached to the shower drain and I can see daylight and the ground through the drain hole.. Is something missing that I need to purchase to remedy this?
Thanks in advance for your replies.. much appreciated
