04-14-2012, 09:43 PM
COASTIE CAMPER
Maiden Voyage
Last night was our trial night. = Fail! We got all set up within 30 minutes including the fire. Took a bit to get the furnace to turn on and when it did it ran for about a hour, releveved the rig and it started back up. 1:30am 34* outside it quit again. Tried to level it, no go. No heat! Even when the furnace was on it was Luke warm at best. How do I fix this? Thank you!!
Alan
2006 Chevy Trailblazer EXT
2007 Flagstaff MH19TH
It's me my wife, 4 kids and our Dani Dog
04-14-2012, 10:42 PM
COASTIE CAMPER
It's a Suburban DD17DSI.
Alan
04-14-2012, 10:50 PM
May have spider web in has tube.
Also try turning off propane valves and turn them back on very slowly
04-15-2012, 11:02 PM
COASTIE CAMPER
Does anyone else have that furnace?
Alan
04-16-2012, 10:19 PM
COASTIE CAMPER
Guess not...
Alan
04-16-2012, 11:33 PM
My unit is at the service department getting items done off my wish list so I can't check to see which furnace I have. Sorry...
Formerly owned 2011 Salem Cruise Lite 20RBXL & 2011 Toyota Tundra Dbl Cab
04-17-2012, 06:36 AM
Originally Posted by Shankster
Guess not...
If you go to the manufacturers web site there
Is most likely a diagnostic flow chart to help u out at
This point. Not sure why you have not gotten a hundred
Different ideas.
04-17-2012, 08:43 AM
Does all the other gas appliances work okay? I found that the first time firing up my furnance I had to turn on the stove to get all the air out of the lines first. After that everything worked as designed. Hope this helps.
Ron, Tami, Annette, and Ron III
United States Coast Guard Active Duty
2011 Salem 28BHSS / 2004 Dodge 2500 Cummins
2012 reserved/ camped ( 17/ 4)
04-17-2012, 10:16 AM
Thoughts for you:
Propane flow:
-Check all other LP systems - stove and HWH. As Ron asked above, are they running normally?
-Are your tanks full?
-Did you open the tanks slowly?
-Could have a little moisture in the propane tanks and, at the temps you were camping at, the regulator might freeze up.
Power:
-Were you on battery or AC? If the battery is low, it might not have enough power to run the fan fast enough anymore to activate the furnace's sail switch or possibly to run the thermostat correctly.
Bad control board:
-If you reset the furnace by turning it off then on again and it works for a while before turning off then I would guess it’s could be a bad control board.
Bad thermostat? Consider replacing with a digital.
Hope this gives you some ideas.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
04-17-2012, 10:33 AM
I also notice that your trailer is a 2007 so it could be six years old. A burner that is clogged with soot or dirty might be a problem with the low temps you felt when it did work.
Below is a manual for your furnace.
Scott
2012 Shamrock 233S
04-17-2012, 08:24 PM
COASTIE CAMPER
Thanks for all of the ideas. I'll check all that when I get back next week.
Alan
04-18-2012, 10:26 PM
COASTIE CAMPER
Checked all above. tried to get the stove and hwh going, no luck. bad regulator??? Thanks!
Alan
04-19-2012, 06:57 AM
Flagstaff 22FBS
Not trying to be a wise guy, but are you sure that you have propane in the tanks?
Deb
Deb & Gary
2021 Ford F150 Lariat 3.5 EcoBoost, 2021 Flagstaff 22FBS
Everybody needs beauty as well as bread, places to play in and pray in, where Nature may heal and cheer and give strength to body and soul alike._ John Muir
04-19-2012, 08:08 AM
Could well be. Check it out. I'm not sure how to do this yourself. I know it involves a manometer, which I don't have so I'd go to my dealer.
Deb
It wouldn't be the first time. In fact, I've done this
Scott
2012 Shamrock 233S
04-19-2012, 08:31 AM
COASTIE CAMPER
No worries. I thought I was outta propane too. I just bought the tank and was about to go ring the guys neck that filled the tank. But yes indeed the tank is full. That's the first thing I checked, along with the ID10T light. thanks
Alan
