Old 08-20-2012, 10:30 AM   #1
Manual Roof-Lift for 2008 Forest River
I've got a newly purchased 2008 Flagstaff, Forest River pop-up, which has the convenient, battery powered roof-lift system. (Except when your mountain bike falls onto and breaks the switch, like it did yesterday!)
I have looked under, over, around and beside this camper and cannot find a manual-crank lift mechanism - nor is there any 'crank' in any of the storage compartments.
Does anyone know, would the manufacturer not provide a manual means to raising the roof on the camper? Or, am I missing something that may be right in front of my face?? Thanks for any insight!
JRWeb is offline   Reply With Quote
Old 08-20-2012, 10:41 AM   #2
Triguy's Avatar
I can't help you with the specifics with this, but will move the thread to the Popup section so more pup owners can see it and may be able to help you.
Good luck!
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 08-20-2012, 11:12 AM   #3
On my 2012 Flagstaff popup, there is a round disc that pops off of the powered lift system near the top of the box. From there, I am supposed to insert a crank device to manually lift/lower the top. It is a separate type of crank than the one to lift/lower the support brackets. Hope that helps. If you need more info, let me know.
Summersby is offline   Reply With Quote
Old 08-20-2012, 11:51 AM   #4
Thanks so much, Summersby! I found the pop-out disc you mention(which I had found before but the hex-nut inside was covered up with grease and being the novice I am, well, nevermind..) Now all I need is the crank to use on it! LOL. Happy camping!
Old 08-20-2012, 11:52 AM   #5
During my walk through, they said to keep that hole filled with grease, so keep that in mind if you plan to use the manual crank often. Good luck!
Old 08-20-2012, 04:03 PM   #6
ittle dew's Avatar
My manual crank ( 2012 228d ) was under one of the mattresses like the bunk bows and corner supports.
Hope this helps
ittle dew is offline   Reply With Quote
Old 08-20-2012, 04:13 PM   #7
Blackrock's Avatar
If I remember right it will take a 1/2" socket. And it is real slow to work with the manual crank. Best thing is to find some way to use an electric drill. As for the switch it is a pretty easy job to replace.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Blackrock is offline   Reply With Quote
Old 08-29-2012, 10:02 AM   #8
You need the crank as stated or a socket to manually wind up/down. re grease that is supposed to be there. Repack with grease when you have finished with manual raising/lowering once you replace your broken switch.
goody59 is offline   Reply With Quote
