Old 07-28-2011, 08:53 AM   #1
mattress wet in 2006 forest river flagstaff
I have a 2006 forest river flagstaff popup ( high wall). Everytime we open it up and set up the mattress under the air conditioner is wet. Is there anything we can do to prevent this? Could this be condensation?
Tblackman is offline   Reply With Quote
Old 07-28-2011, 09:17 AM   #2
So camper is closed, you open it up and the mattress is often wet? Sounds like you have a leak in your roof around A/C unit. Condensation should be draining off the roof. Could this not be rain water leaking in behind the A/C seal? Have you checked your seals or bolts holding the A/C to the roof? I know on my old popup they would get loose often.
2005 Ford Excursion V10 4x4 4.30's
2011 Salem 26TBUD
brianb is offline   Reply With Quote
Old 07-28-2011, 10:53 AM   #3
bikendan's Avatar
first culprit has to be the a/c seal.
Old 07-28-2011, 12:11 PM   #4
Saturday morning I will check AC seal. Sounds like you guys know your stuff.
Thanks!
