04-10-2012, 12:03 PM
COASTIE CAMPER
Mh19th
Good morning/afternoon,
I was wondering if there are any other Flagstaff MH19th owners hanging out here.
Alan
Alan
2006 Chevy Trailblazer EXT
2007 Flagstaff MH19TH
It's me my wife, 4 kids and our Dani Dog
04-10-2012, 05:33 PM
COASTIE CAMPER
I have a question... It has DC breakers in the power panel and when I plug it in to A/C I can hear a inverter/converter or a fan. Not sure. How do I power it off of my battery?? Thanks!
Alan
04-10-2012, 05:36 PM
the converter fan is what your hearing if its on its likely charging your batteries and or running the lights .
what are your trying to power off your battery ?
you most likely do not have an inverter .
04-10-2012, 05:38 PM
if you have NO power for anything without shore power you most likely have a self reseting breaker tripped. Normally located within a foot and a half from battery .
04-10-2012, 06:04 PM
COASTIE CAMPER
It's a WFCO 3 stage converter. Model # WF8725P. I guess I just answered my own question.
Alan
04-10-2012, 06:19 PM
Is that the case ? You have no power when shore is unhooked ?
04-10-2012, 09:31 PM
COASTIE CAMPER
Right. No power when not hooked up to shore power. Although it does have a power lift top and that works off shore power
Alan
04-10-2012, 09:33 PM
Have you checked voltage on both sides of the breaker?
04-10-2012, 09:49 PM
COASTIE CAMPER
Battery side and after the panel? Should I have dc power when unhooked??
Alan
04-10-2012, 09:55 PM
Yes you should.
Follow the positive cable off the battery about a foot and a half
there should be a reset able breaker. It may be tripped assuming your
battery is fully charged there should be 12+ volts on either side of the breaker.
04-10-2012, 09:57 PM
COASTIE CAMPER
Awesome. Thank you! I'm a diesel tech, I hate electricity but I'll give it a shot, dc ain't bad anyways.
Alan
04-10-2012, 10:27 PM
COASTIE CAMPER
No such luck. Battery is only wired up to the power top motor.
Alan
04-10-2012, 10:36 PM
ok I am not sure what you mean by power top motor ?
04-10-2012, 11:03 PM
COASTIE CAMPER
It has an electric motor that raises the roof instead of a hand crank. Well it has a hand crank back up.
Alan
04-10-2012, 11:08 PM
can you post some pics tomorrow ? of battery and connections ?
theres also a safety switch some where that does not allow electrical to work in the down position. that may be stuck . or have a loose connection .
04-11-2012, 08:00 AM
COASTIE CAMPER
I'll put some pictures up later today after work.
Alan
04-11-2012, 08:44 AM
COASTIE CAMPER
Also, the title says MH19TH, but the rig itself says BR19TH. So how bout any BR19TH owners?????
Alan
