I think your only issue (besides where to put it in the PUP) would be overloading your breaker. But that problem is no different than people running on their generator - they can run the AC or the microwave, but not both. Just a matter of coordinating your use.
Or as suggested above, run an extension to the power pole; you might need an adapter to plug in either the extension cord or your normal shore power cord; you'd need to have each plugged into a separate outlet and most power poles have at least a 20 amp and a 30 amp outlet; many also have a 50 amp outlet.
2011 Traverse LT, 3.6L, FWD
