Old 05-26-2012, 09:42 PM   #1
My Lift Cable broke, 6 days till camping!
Today I went to put up my 2003 flagstaff and my main lift cable snapped, the camper top came crashing down from about 4 feet.
I have a camping trip planned for friday so I need this fixed fast. I have already purchased 20' of 3/16 stainless steel cable.
Can anyone help with how to go about replacing this cable? I did read somewhere I need to raise up the roof before I can do it. Is this true.
Again, any help anyone can give would be great.
Thanks.
-Matthew
MatthewJ is offline   Reply With Quote
Old 05-26-2012, 11:38 PM   #2
bikendan's Avatar
you should contact the lift's manufacturer, if there's no paperwork on it, in the owner's manual.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 05-27-2012, 07:03 AM   #3
Make sure that you grease your push springs in the tubes every season to eliminate some stress on the lifting system.
capucine is offline   Reply With Quote
Old 05-27-2012, 07:24 AM   #4
BlakeB's Avatar
Here's a write up on one that may be very similar to yours...
RVGene.com - Forest River Flagstaff and Shamrock
TT = 2014 Palomino Solaire Eclipse 318TSBHK
TV = 2014 Ram 2500 Big Horn 6.4L V8
Pit Crew: DW (Robin)
Kids: 3yo DD (Riley), another DD cookin (Kennedy)
Security: 5yo Boxer (Sasha), 14yo yorkie (Porter)...he was married in
BlakeB is offline   Reply With Quote
Old 06-03-2012, 05:24 PM   #5
Hey Matthew - This just happened to ours today. What did you end up doing?
KSW8989 is offline   Reply With Quote
Old 06-03-2012, 05:40 PM   #6
Hi, Blake gave this link. RVGene.com - Forest River Flagstaff and Shamrock
It worked fine, all you need is 20' of aircraft cable and some ends for it.
Follow the link above to get your cable out and then make a new cable just like it as if it didn't break.
Then put it back in, I have a wench with mine, so I had to adjust the auto stop bolts in it.
I'm no mechanic, computer guy actually, and it only took me 6 hours and 3 trips to the hard ware store.
Not that difficult, but took a while.
You can also go to the dealer, it casts $400 there
-Matt
Old 07-15-2012, 09:40 AM   #7
I am working on a Rockwood Freedome pop up camper with broken cable. I was told to have roof in the down postion. Is this right ? Or should it be raised when putting new cable thru? Acually I have new cable in already but I installed it with the roof down and the roof does not want to go up in the front. Only the back part of roof starts to lift.
Northwoods Camping Supply is offline   Reply With Quote
Old 07-15-2012, 10:11 AM   #8
You may need to adjust the pulley in the rear of the camper if one end starts to lift first. If the end doesn't lift at all you might be missing the clamp on the cable that lifts the end.
Did you buy or make this cable ?
Old 07-15-2012, 10:16 AM   #9
I bought the cable at the store where I work and we put the new stoppers and stuff on where they should be. We even measured to make sure the stoppers were in the right place. Yeah the back starts to raise and the front goes down as the back goes up. Should the roof be up when putting a new cable in> Because I had it in the down postion like I read someplace online. Thanks
Old 07-15-2012, 10:22 AM   #10
It has to be down when installing.
Sounds like the cable is in wrong. What instructions did you follow.
