Old 09-27-2015, 05:37 PM   #11
mystery rod
Received one in our 2514G as well. I have been using it as a prop stick to hold up the lid under the dinette seats and the lid under the couch....sort of a 3rd hand. Seems to be made for this as it holds them open at a good angle for easy access.
61cubby is offline   Reply With Quote
Old 09-27-2015, 06:35 PM   #12
Yes my wife and I use it for 2 things one to push the flaps to the Velcro without needing a step ladder and to push on the light switches
dschlier is offline   Reply With Quote
Old 09-28-2015, 06:30 AM   #13
Ditto 61Cubby. Ours is also a 2514G, we also use it as a dinette seat prop. The dealer told us that is what it is for since the seat back support (nice) prevents the seat from being lifted past about 70deg (not-so-nice)
2016 Roo 21SS, 2016 F150
2015 Rockwood 2514G (pup), 2015 Fd Expl,
2003 Coleman Utah (pup), 2007 Fd Expl
Underthedog is offline   Reply With Quote
Old 09-28-2015, 01:55 PM   #14
TexasRain's Avatar
We received one too in our 2016 HW277. I was thinking it may be a support pole for the dinette slide out (from the base of the slide out to the ground). Could be something equivalent to a third leg...
TexasRain is offline   Reply With Quote
Old 09-28-2015, 02:22 PM   #15
I have the answer! The nice folks at Roberts Sales said it's for the hanging wardrobe. He said if you take the shelves out, you can insert said rod and use it to hang clothes. Go figure. Thanks to this thread, guess I can use it for all sorts of things.
spurticus is offline   Reply With Quote
Old 09-28-2015, 03:06 PM   #16
Now after reading this post I think I might get a pole or 2x4 and use it to hold up (help support) the slide out. Sounds like a great idea.
I think if it was used the slide out would last longer without dipping down in the back.
Great post..
guttafixit is offline   Reply With Quote
Old 09-28-2015, 03:23 PM   #17
NO Guttafixit and Texas Rain don't support the slide out it is designed to have a slight slant. You could damage the slides when the pup moves
kinma13 is offline   Reply With Quote
Old 09-28-2015, 03:28 PM   #18
Originally Posted by kinma13 View Post
No Texas Rain don't support the slide out it is designed to have a slight slant. You could damage the slides when the pup moves
If I have all 4 jacks down how would it move? I wouldn't drive it under there. I would make sure that when some people sit it would hit the jack (pole) or whatever I fab. up. No one sitting in there it would have about 1/8" or 1/16" space.
Old 09-28-2015, 03:31 PM   #19
I really haven't looked at the rails. Are they rugged enough to hold up for years? Or would they get weak over time? Guess I'll take a look at them next time I go out.
Old 09-28-2015, 03:35 PM   #20
Even when you set ur stab Jacks the pup moves a little (stab only stabilize nor lift or support the pup) if you put to much pressure on the stab Jacks you can damage the frame. Yes the pup don't move much but it does flex as most of us enter or exit at least.
