Old 08-08-2014, 11:15 AM   #31
Gforce24's Avatar
Haha! Yeah, that'd me me, trying to be perfect! Thanks Vin! I will definitely follow your suggestions! Getting her ready for the maiden voyage in just under two weeks...I think I'm about there.
Gforce24 is offline   Reply With Quote
Old 08-08-2014, 12:08 PM   #32
w4drr's Avatar
The most correct place to check is the refrigerator. It doesn't work well if it is very far out of level. If it is run out-of-level for an extended time, it could damage it.
Bob & Doris
Roanoke, VA
2009 Toyota Tundra CrewMax 4x4 - 5.7L - 6 Speed Auto - 4.30:1
2013 Rockwood HW296
w4drr is offline   Reply With Quote
Old 08-08-2014, 12:24 PM   #33
W4drr where on the fridge do you check? To get to my fridge I have to almost open everything the beds n the slide. Doing that I would have to unhook the tv
kinma13 is offline   Reply With Quote
Old 08-08-2014, 12:25 PM   #34
Now im curious. I just lay my 24" level on the floor just the door.
Old 08-08-2014, 12:35 PM   #35
Ford Idaho's Avatar
I use one like this.
His Glassworks - Bulls-Eye Bubble Level
Just put it on the bottom of the fridge.
Old 08-08-2014, 12:37 PM   #36
Pill Billy's Avatar
The fridge needs to be level from side to side so the ammonia will condense and recycle correctly.
If your fridge is on the side of your trailer, leveling the trailer from front to back is critical for the fridge.
If your fridge is on the front/back of your trailer, leveling the trailer from side to side is critical for the fridge.
Pill Billy is offline   Reply With Quote
Old 08-08-2014, 02:50 PM   #37
w4drr's Avatar
I checked it on the floor in front of the fridge, and verified it agreed with the bubble level on the hitch jack. Once I had done that, then I was able to trust the level at the jack, and just use it when setting up.
Bob & Doris
Roanoke, VA
2013 Rockwood HW296
Old 08-08-2014, 08:26 PM   #38
vinmaker's Avatar
You guys are right on about the fridge.
I think the OP wanted to level the trailer. I agree that one would hope the fridge would be level if the trailer is level. However, I am not sure if the logic is correct when one says if the fridge is level then the trailer is level.
These things are just not made with the type of precision that one could expect. That is why one needs to take a few level readings to check everything.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 08-09-2014, 06:31 AM   #39
w4drr's Avatar
The idea is, if you are going to pick a spot in the camper that is going to be perfectly level, the fridge should be it since it is the only thing that is sensitive to leveling. Unless something is terribly wrong with the camper frame or the stabilizer jacks have been over-tightened; if the fridge is level the rest of the camper should be reasonably close.
Bob & Doris
Roanoke, VA
2013 Rockwood HW296
Old 08-09-2014, 06:46 AM   #40
Gforce24's Avatar
Thanks guys. Hopefully there isn't anything wrong...it's brand new.
Also, I shouldn't try to level with the stabilizers correct? I heard that is a bad idea.
camper
