Old 08-09-2014, 06:47 AM   #41
vinmaker's Avatar
Ah. Good point Bob. That is so true about the only think mattering is the fridge. lol.
Can't believe I missed that point. Thanks for pointing that out.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 08-09-2014, 06:48 AM   #42
vinmaker's Avatar
Originally Posted by Gforce24 View Post
Thanks guys. Hopefully there isn't anything wrong...it's brand new.
Also, I shouldn't try to level with the stabilizers correct? I heard that is a bad idea.
Right. They just stabilize a bit. Always level with wood/blocks/etc for side to side and the front jack for front to back.
Vin.
2015 HW296
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 08-09-2014, 08:40 AM   #43
Pill Billy's Avatar
Stabilizers are just for stabilizing. If you force them to level you will end up warping the frame which can then cause misalignment issues with your front door.
Pill Billy is offline   Reply With Quote
Old 08-09-2014, 09:32 AM   #44
w4drr's Avatar
I guess I should have emphasised that point when mentioning over-tightened stabilizer jacks. As has been already pointed out, DO NOT level with stabilizer jacks. I just tighten mine until I see just a slight lift of the frame (maybe a 1/4", or so) and stop. I use my cordless drill with a speed socket until they just contact the ground, then finish the job with the supplied hand crank so as to not over-tighten. A speed socket is the best $8 investment a lazy man can make.
Bob & Doris
Roanoke, VA
2009 Toyota Tundra CrewMax 4x4 - 5.7L - 6 Speed Auto - 4.30:1
2013 Rockwood HW296
w4drr is offline   Reply With Quote
Old 08-09-2014, 10:47 AM   #45
LouNick's Avatar
Correct. Level with the tongue jack (leveling legs on the front of a 5er), then just snug up (stabilize) with the rear stabilizers.
A couple more comments:
Not sure about Androids, bit iPhone users have a level built into the phone. Open the compass and swipe across it. Voila!
I like to level at the range cooktop. That way the cooking oil doesn't run to one corner of the pan. 8-)
Lou and Paula
2014 Rockwood 8289WS UltraLite w/Revolution Pinbox Engaged.
2011 F250 Power Stroke Super Duty King Ranch Super Crew Cab w/Reese 16K Hitch
Lou & Paula
2014 Rockwood 8289WS Ultra Lite w/Reese Revloution Pinbox.
2011 F250 Power Stroke Super Duty King Ranch Super Crew w/Reese 16k Fixed Hitch
LouNick is offline   Reply With Quote
Old 08-09-2014, 11:20 AM   #46
Terier's Avatar
Originally Posted by Ford Idaho View Post
I use one like this.
His Glassworks - Bulls-Eye Bubble Level
Just put it on the bottom of the fridge.
I also use a Bulls-Eye bubble level in a few spots along with checking how the bathroom door opens & closes. I often camp on pavement which isn't too unleveled to start with.
Old 08-09-2014, 05:18 PM   #47
stryke-force's Avatar
A BAL leveler is a great thing to have. It not only helps you level side to side but also acts as a wheel chock. Check amazon, about $90 or so.
stryke-force is offline   Reply With Quote
Old 08-09-2014, 05:30 PM   #48
Gforce24's Avatar
Thanks!
Gforce24 is offline   Reply With Quote
Old 08-10-2014, 10:52 AM   #49
Gforce24's Avatar
Ok guys, another question about the levels...I have the stick on kind, but I can attach them permanently with screws. Where would be best to mount these? Is it safe to drill a couple of holes in the body of the box to mount these?
Old 08-10-2014, 05:15 PM   #50
Not sure where to mount them but if you drill holes MAKE SURE YOU CAULK THEM so they dont leak
kinma13 is offline   Reply With Quote
camper
