Old 08-10-2014, 08:04 PM   #51
vinmaker's Avatar
I would not suggest drilling any holes in the exterior. You are just asking for trouble.
I think placing them on the back bumper and side frame would be sufficient. Will not mar the finish either.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 08-11-2014, 08:48 AM   #52
w4drr's Avatar
On previous campers, I have used the stick-on levels, and they seem to do fine for a couple of years before the sticky starts to weather and lose it's grip. No problem...I just bought new ones and replaced them.
Bob & Doris
Roanoke, VA
2009 Toyota Tundra CrewMax 4x4 - 5.7L - 6 Speed Auto - 4.30:1
2013 Rockwood HW296
w4drr is offline   Reply With Quote
Old 08-11-2014, 08:57 AM   #53
vinmaker's Avatar
Exactly. That is what I was thinking. Just buy some new ones if need be. Much better than drilling IMO.
2015 HW296
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 08-11-2014, 09:00 AM   #54
Gforce24's Avatar
I bought the sticky ones and they had the instruction for "permanently" attaching them with screw. I thought about it because the sticky ones seemed to be cheap and very easily moved if bumped. I went yesterday and bout some a little more expensive and stuck those on and they are great. So I went with the sticky ones. Thanks again guys!
Gforce24 is offline   Reply With Quote
Old 10-08-2014, 03:28 AM   #55
Gforce24's Avatar
Hello all! Just an update, things are going well with my new camper! I do have a quick question. As you know I have the 2015 HW 296. I've been dry camping and everything's been great. Next weekend will be my first time with full hookups. My question is on this model, the grey and black water tanks have separate drains. They are totally different sizes. With full hookup, how would I set them both up to drain simultaneously?
Old 10-08-2014, 05:13 AM   #56
GalsofEscape's Avatar
You dont . Hook up the gray to the sewer while you are camping. Then once the black tank is full then hook that one up and dump it. You do not want to have the black tank draining to sewer as you camp as solids will build up in the tank, so you only want to dump the black when it is at least a three quarters full. If it is not at least that full, add water to get there. If you are interested, some people have done a mod to connect the two outlets into a single, that way they use stored gray to rinse the hose after a black dump. Search for that here on the forum. Have a great time camping....
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Bruce" 2011 Dodge Durango V8 Hemi Crew
Just us gals (me, Sis and our daughters)
We spend alot of money to go sit in the woods
GalsofEscape is offline   Reply With Quote
Old 10-08-2014, 08:34 AM   #57
Gforce24 most of us dont connect them together like GalsofEscape said you dont want to so you can flush the hose after draining the black. A couple of us went to the hardware store
( lowes) and got plumbing fitting so we can connect a stinky slinky to the gray outlet. You need
1 1/2 cleaning out
A 1 1/2 to 3" reducer and then a valterra bayonet from amazon the glue it all together. Ill post pics and part numbers when I find them. Vinmaker also might have them still
kinma13 is offline   Reply With Quote
Old 10-08-2014, 08:58 AM   #58
msantos's Avatar
Welcome from Texas congrats on new popup
msantos is offline   Reply With Quote
Old 10-08-2014, 09:06 AM   #59
valterra T1029-1 termination adpator from amazon
charlotte pipe 1 1/2 clean out 23301 from lowes
charlotte pipe 1 1/2 x 3" adpator coupling fitting 23319 from lowes.
vinmaker from them in black but lowqes in michigan only have white.
Old 10-17-2014, 02:31 PM   #60
Gforce24's Avatar
Another quick question...when hooked up to full hookup, or city water, do I need to use the water pump?
camper
