Old 01-08-2011, 09:19 PM   #1
New hi wall
We bought our camper new in 2009. Ever sins owning it the lift motor for the roof never work. The roof will stop 3 to 4 times until the breaker resets. Their is a ac unit on top. The unit is still under warranty but the dealer has made repairs 6 times with no improvements. Any suggestions
Smith camping is offline   Reply With Quote
Old 01-08-2011, 10:00 PM   #2
acadianbob's Avatar
Geez, is there another dealer around?
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 01-08-2011, 10:41 PM   #3
grhodes50's Avatar
Yeah, I would look for another dealer or maybe get in touch with the manufacturer of the AC unit and the electric lift motor. They might can tell you of a different authorized repair shop near you. Direct contact with FR may help as well.
ROCKWOOD TENT CAMPERS / FLAGSTAFF TENT CAMPERS / HIGH WALL CAMPERS
Cindy Dahm / Main phone number (574) 642-2640, Ext. 118
E-mail: cdahm@forestriverinc.com
Fax number: (574) 642-4999
Hope this info helps.
Gary & Trish
2018 Nights Camped - 5
Old 01-09-2011, 06:43 AM   #4
We have the same problem on our 2009 flagstaff 228d - breaker resets & lift motor works another 30 seconds (really slowly), then trips the breaker again. Replaced the battery, but that didn't help. No local dealer, and the selling dealer isn't interested.
Finally resorted to traveling with a heavy duty drill to do the lifting; its slow but does the job.
Alan
oldlurker is offline   Reply With Quote
Old 01-09-2011, 07:44 AM   #5
It sounds like they simply didn't put a big enough lift motor on it, thus it is overloaded, heats up, and flips the breaker.
You could try putting a bigger breaker in, as I wouldn't think the motor would melt in the time it takes to lift the roof. If the motor does burn out, it shouldn't be too hard to find a bigger one.
Old 01-09-2011, 12:16 PM   #6
The dealer did put a higher amp motor on the camper and now it cuts out less. You would think they would make a heavier unit. If a heavy duty drill will work than why can't they make something that will work
Old 01-16-2011, 12:07 AM   #7
Maybe something is causing a jam and binding the system.
Without the drill:
Dose it crank up smoothly by hand, or do you feel any resistance?
I would take all purchase/warranty and repair documents to a lawyer and have him/her fax them to Rockwood and ask for help.
The lawyer may cost you $250 or so, but you should get results. They need to reinburse you for your time and trouble which should at least off set the lawyers fee and then some.
Above all, I wouldn't let this go, and I would have done this before 6 trips to the dealer.
6 return repair trips, thats 5 to many!
Politicians should be required to wear uniforms like NASCAR. At least the TAXPAYERS would know who their corporate sponsors are !
Squall Line is offline   Reply With Quote
Old 02-21-2011, 04:22 PM   #8
Up date up date!!!!!!!!!! We returned to Tom Raper in Indy. The general manager has went out of his way to take care of our problem. They are picking up the camper at our house and the president of forest river and the general manager are going to test the lift system before they call us to pick it up. The manager said it would work or they will make it right. They are also going to give us an apple I pad for our trouble. We are so happy as long as our camper gets fixed
Old 02-21-2011, 04:51 PM   #9
good happy F R did it for you
jutojohn is offline   Reply With Quote
Old 02-21-2011, 11:22 PM   #10
Thumbs up
Smith camping, CONGRATS to you !!!
I hope you give them h@ll for the poor dealership responce to your problems !!!
As I stated above...
"6 return repair trips, thats 5 to many!"
now #7 makes it
"7 return repair trips, thats 6 to many!"
TRUST ME, Rockwood dose not want - or need - ANY bad press this tight market!
