Forest River Forums
Sunline User Photos
Old 09-26-2011, 06:45 PM   #1
New Owner- Basic Electrical Help
Hello- I just bought a used '99 Flagstaff 206 LTD pop-up camper. I am really a novice when it comes to this stuff, so bear with me... I am having a difficult time getting the power (both 12v and 110v) to work properly. When I have it plugged in, only some of the lights work (the bulbs are fine). When I try the to run it off of the battery, I can't get any power. I have a battery charger and charged the battery before I tried it. Any suggestions? Is the power converter in the access panel behind the fridge the only converter?
Thanks for the help!
-Scott
SalingAway is offline   Reply With Quote
Old 09-27-2011, 12:15 AM   #2
Moderator
Hello, and
While I can't help you, I moved this thread into the Flagstaff tent camper discussion. I felt maybe it would get more views here, and give you a better chance of getting an answer. Good luck, and be sure an post the answer when you find it.
Might want to do search in this discussion and see if there is anything here that may help.
Windrider,
Too many toys, not enough time.
2001 F150 SuperCrew
2002 Jeep Wrangler
1978 Cessna 152
2000 Honda 750 Nighthawk
2008 Work and Play 18LT
windrider is offline   Reply With Quote
Old 09-27-2011, 06:26 AM   #3
Flagstaff 625D Popup
Scott,
Check the fuses. And if you have a flip-up galley, there is a switch that disables the lights if the galley is not down the whole way (in the usable position).
Bean
bean is offline   Reply With Quote
Old 09-27-2011, 07:36 AM   #4
grhodes50's Avatar
You should also have an inline fuse near the battery. I believe it's a 30 amp and from your description it could be bad.
bean may have the answer as to why you are only getting some of the lights to work.
Gary & Trish
2011 LaCrosse 303 RKS Touring Edition : 2007 Flagstaff 206ST MAC Series
2010 F-250 XLT : FX4 : CC : SB : 6.8L V-10 : 4/10 Gears
2012 Nights Camped - 5
Old 09-27-2011, 10:16 AM   #5
Thanks for the advice grhodes50 and Bean. I will check and see if the switch at the flip up galley and see if that is it. I did replace the in-line fuse at the battery, so that should be OK.
-Scott
electrical, flagstaff, power
» Online Users: 573
115 members and 458 guests
2011sv264, 2lvrvn, 4bnabird, 4Jeeperz, Adony, adp1326, armcor02, ayotte, Bigmatt, bikeman911, bikendan, bka4tcu, bmcgee, bob213, Bob_Loblaw, boubou, Buffalohunter, bush, buzzmonster, Cccross3, cgreen1509, chevy02, cllecr, COcamper, crawford, cyclepuck, dashonthedash, dasimser, daw592, DDC, ddemme, DeeMax, dezolen, donn, Drmstx62, Dutch & Di, fast murray, Fire Instructor, forensicdeac, FreedomTracker, gb73071, gimp425, GlacierGus, greran, h20ski, hark582, Hilgy, hjmiberry, House97, itat, Itsthetwoofus, J McClure, J R, JamesR, jasni, jimandjoyhamel, jjhwisconsin, JJL, jking, johnthecamper, jsutherl, jtstromsburg, KRS, kwjeepxj, Mad4sax, manvel, Margaret, Marsh707, meatguy, michel, MikeT, Mnflyboy, MrAllen, mtfd515, mwilson949, ncgrl1, NO3putt, nowait, ohiobill, partime, patov6, Pawpod, peaeye, Phil1, Phil57, PHS79, punkaccountant, rgfenner, RJHuser, rkswyo, rmason8092, RockyMtnHigh, Rsgtivr6, sbond, Sg6923, SinkorSwim, Smithee, snackage, sprayking, Stedman1, steeleshark2, sundawg, Swinks, tentcamper1, Terier, thehamguy1, thom01, Tincup13, tking1866, troyt, VinceU, vp22er, Waterfowlwarrior, WestCoastRV'er, Westernflyer
Most users ever online was 1,025, Today at 01:04 PM.
Close [X]
