Old 10-30-2012, 06:34 PM   #1
Smile New Owner of used Pop-up trailer needs advice.
Hello, this is our first camper, we enjoyed it this summer and now that it is getting cold out, I have no idea as to how to drain the water tank. Cannot find any drain anywhere. So I turned to this forum. I hope you can help.
It is a Rockwood Pop-up, year is 1999. Has anyone an owners manual or advice as to how to empty the water tank....
Thanks,
Rick
Wisconsin Newbie is offline   Reply With Quote
Old 10-30-2012, 07:35 PM   #2
Welcome to the forum
The tank on my palomino was under the bench seat. You had to open the seat and the valve was attached to the tank and a short hose ran to the outside. I put a valve on the outside so it was easier to empty.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 10-30-2012, 07:45 PM   #3
Triguy's Avatar
I'll move this to Popups so it gets more exposure.
Also, we have an old manual from 2004 for Rockwood pups but I honestly don't know if t will be any help to you. Here it is just in case it is usefull.
2004 Rockwood Popup Owner's Manual
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 10-31-2012, 12:02 AM   #4
Thanks for the replies!
I will check them out tomorrow. Hope it works. Getting pretty cold at nite here. I have been manually pumping the sink faucet. I read in the manuals on this site that there may be an electric pump, I never found one but it would be faster! LOL
Thanks again for your replies.
Rick
Old 10-31-2012, 02:36 AM   #5
bikendan's Avatar
Rick
if your faucet has a pump handle, then that means you don't have an electric water pump.
if you did, the faucet would look like your home one and there would be a red switch marked "water pump".
we had two popups and neither had a electric water pump, just the manual pump faucet.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 10-31-2012, 10:48 AM   #6
We added a ShurFlo demand pump to our pop up aftre we got tired of hand pumping. Work fine on a std pop-up style sink fawcet.
We even removed it when we moved to larger TT's so now I have a spare.
Cathy & Jeff
Midland, Michigan
2013 Sabre 32RCTS / 2012 Ram2500 Hemi
SimchaSabre is offline   Reply With Quote
Old 11-30-2012, 02:06 AM   #7
My drain plug on my 2280 in underneath the trailer. I had to lay on the ground to see it under there.
femetal1 is offline   Reply With Quote
