Old 10-06-2015, 06:38 AM   #11
2gwright's Avatar
Or just hard plumb the system and never worry about it again.
One 3" connection point and two valves. There are several
posts about this and it is also inexpensive. A search under my
name should locate the post.
ID:	90785   Click image for larger version
2015 HW296
2gwright is offline   Reply With Quote
Old 10-06-2015, 07:36 AM   #12
2gwright, the plumbing looks nice but how the heck do you pull the black valve? I have a hard time the way it sits, my pup is low.
kinma13 is offline   Reply With Quote
Old 10-06-2015, 07:37 AM   #13
Do you think the Parts I posted for the Gray Tank mod will work?
cleight is offline   Reply With Quote
Old 10-06-2015, 09:02 AM   #14
2gwright's Avatar
It's a little awkward of an angle but not enough to purchase the remote handle kit
that is available for these valves. I had to rotate the valve that way because the
jack was installed just aft of the valve and is in the way.
I did not look at your parts list but I got the double valve on Amazon and the PVC
pipe at home depot.
http://www.amazon.com/gp/product/B00...ilpage_o06_s00
2015 HW296
Old 10-06-2015, 12:15 PM   #15
cleight i think the parts you listed might not work.
the amazon 1 might be ok but the amazon 2 needs to thread to the outlet on the pup and the lowqes pic dont come up. if your lowes dont have my parts list in black (abs) black paint works fine.
Old 10-06-2015, 01:15 PM   #16
Here's a pic. Works like a charm!
spurticus is offline   Reply With Quote
Old 10-06-2015, 01:36 PM   #17
Spurticus,
Do you also have a hard time disconnecting the hose without the ad parter trying to unthread? Mine does but I think it's because I really don't have a great grab power with my right hand ( disabled) was thinking of plying it on but not sure I want to. Going to lowes tonight n see if they have some kinda 1 1/2 nut I can use as a jam nut.
Old 10-06-2015, 01:58 PM   #18
Spurticus,
I just hold it while disconnecting the hose. No issues overall.
Old 10-11-2015, 08:19 PM   #19
Just got back from taking our HW277 out on our first trip and found some issues. Has anyone had issues with water leaking out around the bottom of the toilet and under the bathroom itself onto the floor?
Sent from my SM-G900V using Tapatalk
Old 10-11-2015, 08:33 PM   #20
GalsofEscape's Avatar
We have that issue. The source of our problem is when we fill the gray tank, it no longer backs up onto the shower, instead it flows under the shower floor and across the floor. In order to fix, the repair place said that they would have to remove the bath to get to it. Since we were no longer under warranty, it is not worth it to fix, we just use an external waste tank.
If you are under warranty, i would get the dealer to look at it.
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Bruce" 2011 Dodge Durango V8 Hemi Crew
Just us gals (me, Sis and our daughters)
We spend alot of money to go sit in the woods
GalsofEscape is online now   Reply With Quote
