Old 10-05-2015, 08:00 AM   #1
New owners of a NTU HW277, Have some questions
Hello fellow campers,
My Wife and I recently purchased a used 2013 Rockwood HW277 Pop-Up and have some questions that hopefully can be answered from other 277 owners.
1. Where are the Lift System Support Braces and Bunk End Support bars typically stored? When we purchased the unit they were laying on the floor and sliding around and scratching the cabinets.
2. Is it normal to not have any level bubbles on the unit?
3. I am looking for a gray water tank adapter so I can use the Black water 3" RV Hose with the gray water discharge. Can someone point me in the right direction?
Other than these couple of questions we really like the unit so far and will be taking it out on it's first trip this weekend.
cleight is offline   Reply With Quote
Old 10-05-2015, 08:08 AM   #2
We don't have a high wall but we store our poles under the respective beds. Our safety bars lay on the dinette and as for the bubble those are user applied. I prefer to trust a torpedo level or 2 foot level if I remember it.
We have a 2317g premier so we don't have a gray or black hook ups. So someone else will tackle that.
Me the missus and three hooligans!
2014 Rockwood Premier 2317g
2012 Ford F150 super crew ecoboost
2011 Honda Pilot
3hooligans is offline   Reply With Quote
Old 10-05-2015, 09:05 AM   #3
Question 1. I store my shepard poles and lift support under the front matress,
Question 2. No but you can install them.
Question 3. Use a 1 1/2 clean out, a 1 1/2 to 3 riser, and a valterra bayonet terminal. I'll look up parts later. There is a parts list under a decision black holding tanks.
kinma13 is offline   Reply With Quote
Old 10-05-2015, 09:17 AM   #4
Question 3. Parts list
At lowes and make sure it all fits b4 glueing. All should be charlotte, the valterra is at amazon
1 1/2 to 3 charlotte adapter part number 23319
1 1/2 charlotte* clean out adapter part number 23301
Valterra termination adapter part number T1029-1
Old 10-05-2015, 09:26 AM   #5
Georgia Frog Rally 2018
aceinspp's Avatar
Welcome to forum. As you can see lots of help here already. Enjoy your new camper Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 10-05-2015, 09:32 AM   #6
GalsofEscape's Avatar
Hello and congratulations on your hw277. Ours is a 2010 year and we have had alot of use out of ours. We do store the tent poles (the shepards poles) under the mattress. However, the bed support poles we do store on the floor. they slide between the dinette slide out and the fridge cabinet. We have not had them slide around and they are easy to get out and install before you slide the beds out.
As already mentioned, bubble levels do not come with the camper. We bought and installed them.
Hope you enjoy your 277 as much as we have enjoyed ours..
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Bruce" 2011 Dodge Durango V8 Hemi Crew
Just us gals (me, Sis and our daughters)
We spend alot of money to go sit in the woods
GalsofEscape is offline   Reply With Quote
Old 10-05-2015, 09:45 AM   #7
Thanks for all the help and quick responses already. I found the following parts on Amazon that I think would be a straight glue up, and would only need a single fitting from Lowes to tie it all together, can someone confirm?
Amazon - Fitting 1
Amazon - Fitting 2
Lowes - Fitting 1
Old 10-05-2015, 12:03 PM   #8
catseye's Avatar
fwiw, I too store the bed end supports in the aisle. I have a carpet runner and there doesn't appear to be an issue with stuff slipping and sliding.
catseye is offline   Reply With Quote
Old 10-05-2015, 01:26 PM   #9
marsh's Avatar
We too store the slide out support poles and the 2 corner roof supports on the floor and no problem with cabinets being scarred.
marsh is offline   Reply With Quote
Old 10-05-2015, 07:31 PM   #10
Amazon - Fitting 1
Amazon - Fitting 2
Lowes - Fitting 1
I believe all three are wrong. Be sure to get the valterra 1029-1 not 1029-2. Also, I ordered all abs (black) fittings from Lowe's.com. my local Lowe's did not carry abs in store. Be sure to use an all purpose glue that's good for pvc or abs just in case you end up with different materials. There's a lengthy thread around here with the part numbers. Try looking up the parts listed by Kinma13
spurticus is offline   Reply With Quote
