Old 04-03-2016, 10:10 AM   #11
If you can't get the strap around the tray, I think I'd replace those self-taping screws with bolts and nuts and some large fender washers. Batteries are heavy and a few small self-tapping screw heads don't seem like enough to hold it.
2011 Traverse LT, 3.6L, FWD
Old 04-03-2016, 05:13 PM   #12
I happened to have a chance to go by my trailer in storage today. My box appears to be attached with 3 sets of nuts/bolts/washers, and the strap is below the box, but not around the rack.
Not sure why there's water in it; we did have some really hard rains with 40 mph winds, but I still wouldn't have expected the water.
Name:	Battery Box 1.jpg
ID:	103778   Click image for larger version
Name:	Battery Box 2.jpg
Old 04-03-2016, 05:20 PM   #13
Flybob's Avatar
I noticed that my battery box was not connected to the frame, but simply held on by the strap around the box and the frame. I have never had a problem. On another note, Many of the battery boxes have small vents in the top. These allow water in when it rains. The battery box does not come with any drain holes. I drilled 1/4" homes in the bottom in each corner. No longer have water collecting in battery box.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-03-2016, 06:53 PM   #14
Thanks for the pictures; the attachment on your battery box looks much sturdier than mine. Is there some sort of rubberized coating on the head of the bolts? It looks orange in the picture.
Also, is that an Andersen No-sway WDH bracket? We use that system and have really liked it.
Metadifluoro
2015 Rockwood 2318G
TV: 2011 Toyota Sienna LE
Metadifluoro is offline   Reply With Quote
Old 04-03-2016, 07:44 PM   #15
Metadifluoro
Orange = rust.
Old 04-04-2016, 01:29 PM   #16
From what I've been reading the battery is installed at the dealership. Not at the factory. So it might not be an issue for most. I put the strap around the frame for the time being and I will be adding some bolts/screws to it.
Wygantmb is offline   Reply With Quote
Old 04-06-2016, 09:07 AM   #17
maccve's Avatar
My battery box is screwed into the frame. The strap is just there to hold the lid in place...I just replaced my strap yesterday as it was getting rotted out.
Mac's FJ
maccve is offline   Reply With Quote
Old 04-07-2016, 11:10 AM   #18
Does your battery rest on top of the screws? Any concern about the battery not being flat/sturdy with the screws sticking up?
brett2077 is offline   Reply With Quote
Old 04-07-2016, 11:43 AM   #19
Just A Member
EDABEUT's Avatar
One of the first mod's I did on mine. I bought a new battery box that the lid locks on to the box and screwed the box down onto the frame. Thru that strap away. Then added a battery disconnect beside the battery.
Ed & Brenda
2015 Coachmen Freedom Express
Liberty Edition 297RLDS
2013 Silverado 1500 4x4 6.2L Max Tow
EDABEUT is offline   Reply With Quote
Old 04-07-2016, 11:50 AM   #20
Pickin' & Campin'
Make sure if you attach the box (if using the supplied self-tapping screws) that you place the screws in a part of the battery box floor that sits below where the battery sits.
If you sit the battery directly on the screw heads, they WILL rub through the bottom of the battery!
Days Camped: '15=22 '16=46 '17=30 '18=4
battery, pop up
