Old 04-07-2016, 11:52 AM   #21
Thanks 5picker! This is why I asked, didn't seem like a good idea, just wasn't sure if there was risk or not.
brett2077 is offline   Reply With Quote
Old 04-08-2016, 10:27 AM   #22
maccve's Avatar
Originally Posted by brett2077 View Post
Does your battery rest on top of the screws? Any concern about the battery not being flat/sturdy with the screws sticking up?
The screws on mine are located in the low areas of the Battery box, so they sit below the battery. The box is not flat on the bottom.
Mac's FJ
maccve is offline   Reply With Quote
Old 04-08-2016, 09:24 PM   #23
HONDAMAN174's Avatar
New popup battery concern.
I leave my unit in storage and when I had popup I took batteries with us. Bought bigger TT and installed these. No chance of going anywhere now.
http://b-drvbatterylock.com
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
Old 04-17-2016, 09:53 AM   #24
Hello,
The weather was finally good enough to get out and do some work on the popup. The battery box has now been securely attached to the metal tray with reinforcing plates, Phillips head machine screws and lock nuts. Just drilled the holes and tightened everything up. Before and after pictures are attached. Even got lucky enough to get another screw through the strap. Hope this helps anyone else in the same situation.
All the best,
Metadifluoro
Before.
Name:	ImageUploadedByForest River Forums1460904692.760271.jpg
After
Name:	ImageUploadedByForest River Forums1460904789.128013.jpg
2015 Rockwood 2318G
TV: 2011 Toyota Sienna LE
Metadifluoro is offline   Reply With Quote
Old 04-19-2016, 09:25 PM   #25
MNtraveler's Avatar
Nice way to do it. Probably much better than single screw pressure points which are sure to wear right through.
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
battery, pop up
