Old 05-27-2014, 03:55 PM   #1
New pup
We just got a 2013 model HW 276, and I wanted to see if anyone have remedied the problem of having to change the drain hoses for the black and grey water tanks...
dalew20121 is offline   Reply With Quote
Old 05-27-2014, 03:59 PM   #2
rburns4147's Avatar
I am not familiar with the HW 276 but I did want to welcome you to the forum. I am sure someone will be around that is familiar with the unit.
Ron and Elizabeth
2014 Rockwood 8285-IKWS
2006 Ford F250 6.0 Diesel 4x4
rburns4147 is offline   Reply With Quote
Old 05-27-2014, 07:47 PM   #3
I also have a hw276 with the same. i found this post from someone else and it looks to me that it will work ill be doing this over the weekend and ill post pics of it
Here's a easy fix for the grey tank- get a Valterra T01-0091VP
then a camco 39533. connect the 2 with a small hose (should be garden hose size i believe. then just connect the rinse cap to a Camco 39812. then connect your black sewer hose and y pipe to the drian. hope this works.
kinma13 is offline   Reply With Quote
Old 05-27-2014, 07:47 PM   #4
picture courtesy of hondaman174
Old 05-27-2014, 07:51 PM   #5
these pictures of the fix is courtesy of hondaman174
im going to uise a y pipe and hose to connect the hose rinser and sewer hose but i have read the parts can break do to the weight but we ll see. ill take pictures when the parts are all shipped to me. still waiting.
Old 05-28-2014, 09:24 AM   #6
w4drr's Avatar
I have never seen it to be much of a problem since you keep the black tank valve closed anyway until time to dump. Even the small (12 gal) tanks in the 276 and 296 can go an entire weekend, or longer by keeping the flushing to a minimum. When time to dump, close the valve on the gray tank, remove it's hose from the sewer connection, and hook up your sewer hose for the black tank and dump. For the gray, I use the Valterra T01-0091VP previously mentioned, a regular garden hose, and a Camco 39322 3/4" hose to 3" sewer adapter.
Bob
Bob & Doris
Roanoke, VA
2009 Toyota Tundra CrewMax 4x4 - 5.7L - 6 Speed Auto - 4.30:1
2013 Rockwood HW296
w4drr is offline   Reply With Quote
Old 06-02-2014, 12:36 PM   #7
this is what im going to try out. not sure how it will work. kinda long setup not that fast but for a full hook should be good. havent mod the riser control valve yet
Sent from my SCH-I535 using Forest River Forums mobile app
