Been meaning to ask a follow-up question...
So I noticed that the factory ProRac roof rack rails on the new roof are not spaced the same as on the original roof. Originally they were about 35" apart; on the new roof they are about 24" apart...
I don't think it will be a big issue with any accessories I plan on mounting on the rails, but upon closer inspection, it looks like the dealer took the rails off the old roof and installed them on the new roof but changed the spacing in the process.
Makes me wonder if I should lift the risers off the mounts and make sure they did a sufficient job of sealing them up... (And maybe add a bead of ProFlex under each one just to be sure) Anyone on here have any experience with the ProRac rails? Are they prone to leaks if not installed "just right"?
Here is the link to the ProRac installation instructions:
https://www.prorac.com/root/pdf/SAH303-IS.pdf
(These are the instructions for a screw-down mount; for a fiberglass roof it is basically the same except using through-bolts instead of screws... Not sure exactly how they are secured on mine.)
Any advice?
Thanks!
Josh
