Old 10-14-2014, 07:03 PM   #21
JackFrostWinter's Avatar
if thats ALL your gonna use , then yes , by all means 30 amps will more than suffice . But , as I previously said ... if you by chance use a Igloo / Coleman ( and there are other names ) of the peltier ( TEC ) style coolers that plug into 12 volt DC , and will run off the inside of your pup ,while traveling from ( say - --- ) Denver Co to Cheyenne WY and need extra cooling space , more than your little 3 way fridge can handle ,... well .. like I said ... those coolers use a LOT of amperage . so , if your not by chance going to use one , then now worries mate ...
Fun is where you make it
JackFrostWinter is offline   Reply With Quote
Old 10-14-2014, 07:08 PM   #22
Thanks Gals. sums things up beautifully.
megsfinlay is offline   Reply With Quote
Old 10-14-2014, 07:10 PM   #23
Thanks Jack! We don't use the plugin coolers. We have Yeti brand coolers.
Old 10-14-2014, 07:10 PM   #24
GalsofEscape's Avatar
Welcome
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Bruce" 2011 Dodge Durango V8 Hemi Crew
Just us gals (me, Sis and our daughters)
We spend alot of money to go sit in the woods
GalsofEscape is offline   Reply With Quote
Old 10-21-2014, 09:44 PM   #25
I think that first, I would take the battery out of the box, haul it off to my nearest
Auto Parts store and let them charge it and test it to see if it's any good.
If bad, then replace it and retry lights, etc.
If you are still getting the beep signal then check out the converter.
A local electronics repair shop should be able to fix it for you if it's the problem.
Presumably you have checked all the fuses. (AC & DC)
Frank Mattox
2013 GMC Terrain
2010 Palomino Y-4124 popup
fmattox73 is offline   Reply With Quote
280, converter, palomino
