Old 08-04-2016, 06:04 PM   #21
Thank you f5moab, agree with you on this matter
JPBar is offline   Reply With Quote
Old 08-04-2016, 06:24 PM   #22
wbdavey's Avatar
Originally Posted by railroaderone View Post
Hate to hijack this but can bearing buddys but used on a TT
Short answer is NO! The EZ/Ultra lube axles are drilled so that grease passes through the center of the axle to the back side of the inner bearing. Then the grease passes through the inner bearing, the cavity between the bearings, and through the outer bearing before the excess grease comes out around the end of the outer piece. Bearing Buddies only pressurize the bearing cavity to keep water out of your boat trailer bearings at the launch ramp. IMO, If used on a TT they will almost certainly over pressurize the bearing leading to grease all over your brake shoes.
2015 Rockwood Ultra Lite 2604 WS. Rear LR, large street side slide with small wardrobe slide in BR.
2014 Ram 1500 Eco Diesel Laramie Quad Cab.
wbdavey is offline   Reply With Quote
flagstaff, newbie
