Old 06-14-2015, 09:51 PM   #11
VinceU's Avatar
Originally Posted by Bcmjr View Post
When we got home today and unhooked, I switched on the porch light a few hours later and it did light. It was not working at the campsite this morning before we hooked up. Looks like the TV is charging the PUP battery.
Check the converter for blown fuse(s). They have two reverse polarity fuses built in to the casing to prevent someone connecting DC current in reverse, will blow the unit if unprotected. Usually mounted on one end panel or the other.
Old 06-15-2015, 01:51 AM   #12
We had a similar thing happen and it turned out to be a fuse off the battery in the front of the TT. We were stumped why we had full power plugged in but nothing on 12v, even though we knew we had a fully charged battery. Hope this helps!
traciben01 is offline   Reply With Quote
Old 06-15-2015, 02:02 PM   #13
Centech digital voltmeters from Harbor Freight work fine and low cost.
Harkerr is offline   Reply With Quote
Old 06-15-2015, 08:50 PM   #14
I did pick up the Centech voltmeter and battery on the PUP read 11.84 volts. I plugged into shore power, checked a little later and the battery was at 11.83 volts. Once again, the fuses/breakers look good. Thinking that the issue is with the converter.
Bcmjr is offline   Reply With Quote
Old 06-15-2015, 09:40 PM   #15
f5moab's Avatar
Might be time to take a trip back to the dealer.
f5moab is offline   Reply With Quote
Old 06-15-2015, 10:15 PM   #16
Definitely not charging. 11.8 is a low battery. 14+ charging. 12.9-13.1 maintain. Full charge rest state 12.6
Old 06-16-2015, 07:24 PM   #17
Salem Cruise Lite Owner
Bushbunch's Avatar
Happened to me once. I had a battery charger with me with a 2 amp trickle charge option. I attached that to the battery terminals and power restored.
Bushbunch is offline   Reply With Quote
electric, electrical, newbie
