Old 06-09-2015, 12:20 PM   #1
Reuben
Newbie HW276 Pop up (help)
Thanks for any advice - I am a newbie so go easy please. Just picked up a 2012 HW276 popup & have it almost all figured out. It came with two safety roof supports (the metal channel that you place up on the roof extensions during set up). Shouldn't there be 4 - one for each corner?
Reuben Sandwich is offline   Reply With Quote
Old 06-09-2015, 12:22 PM   #2
No just 2 place the at opposite corners.
Across from each other
kinma13 is offline   Reply With Quote
Old 06-09-2015, 04:48 PM   #3
f5moab's Avatar
You might wish for two more if the winds pick up to over 50 mph But from experience, the roof still holds.
f5moab is offline   Reply With Quote
Old 06-09-2015, 05:26 PM   #4
Roll up ur awning or tie it down. Winds can bend the poles easily.
Old 06-09-2015, 06:15 PM   #5
f5moab's Avatar
Never a problem with me!
Old 06-11-2015, 09:52 AM   #6
Rigging a tarp around the bottom of the rear bunk can give you a nice place to stow gear, out sight & out of the weather.
2008 Forest River/Flagstaff M-205 Mac
2006 Toyota Sequoia
OutOfTheTent is offline   Reply With Quote
Old 06-11-2015, 08:40 PM   #7
HONDAMAN174's Avatar
Yep- in a blink, your pole is broken off. And if anyone needs it, have a economically correct way to fix a broken pole mount.
Just glad to get away
Old 06-12-2015, 05:19 PM   #8
marsh's Avatar
...ie...left front, right rear or right front, left rear.
marsh is offline   Reply With Quote
Old 06-13-2015, 07:54 PM   #9
I have a Rockwood 1640 LTD. I only have one safety support. Is that because it is only an 8 foot box or do I need to order another support?
bpapagni is offline   Reply With Quote
Old 06-14-2015, 06:40 AM   #10
vinmaker's Avatar
I suspect you should have two supports also. Only one will not work if the back/front wanted to fail. You need at least one in the front and one in the back.
You can easily use a simple 2x4 cut to the length of your other support and attach it to the roof support with a few bungee cords. I have seen people do that.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
newbie, pop up
