Old 04-07-2014, 11:02 PM   #11
loobdyloo5's Avatar
Hmmm weird. We just purchased a Forest River 282TXR off road pop up. I too have found leaking from the slide out dinette. Underneath on the left side. Not sure what is causing this?
loobdyloo5 is offline   Reply With Quote
Old 04-10-2014, 08:58 PM   #12
HONDAMAN174's Avatar
Tswiii- before I traded I my popup, I had a similar water leak. As stated above, pull up the dinette cushions and there should be a board with a hole in it- pull up that board by using the hole. Sometime the water lines rub against the wood as the slide out moves in and out or a clamp might be weak. All speculation right now. I traded my unit into Johnny walker's on boulder at flamingo- if you need to take it for service ask for Ed. My unit (TT) is there now for warranty work. If you are still having trouble locating the leak, send me a private message as I may be in Henderson on Saturday afternoon- could give a hand locating/reparing/giving opinion.
Just glad to get away
leak, newbie, water, water leak
