Old 06-18-2013, 07:34 PM   #1
No battery power / Fuse keeps popping
Hello, I've got a issue I was hoping to get some advice on.
I have a 2007 Flagstaff 208 MAC that I purchased last year. When I pulled it out this year, I noticed the battery power didn't work on our second camping trip.
On the converter panel, the upper-most fuse (20) was blown and the accompanying red light was on (when plugged into shore power). When I replaced it, the power meter shows a Fault of "Low Voltage" and and when I plug the camper into shore power, the fuse blows out immediately.
My battery is dated from 2009, so it may need to be checked/replaced, however I'm wondering if it make sense the fuse would continue to blow as soon as I plug in from a dead battery? That doesn't seem to make as much sense to me, but who knows. I've checked the wiring and "reset" the power outlet that resides next to the converter.
Any advice on this would be greatly appreciated! Thanks!
coloradorookie is offline   Reply With Quote
Old 06-18-2013, 07:37 PM   #2
TURBS's Avatar
First of all yes the battery needs to be checked and see if its good or not.
Second the converter need to be checked.
If it's a wfco in here you'll find the troubleshooting guide.
Forest River Forums - Downloads - Power and Electrical
Old 06-18-2013, 11:20 PM   #3
Ok, gonna check/replace battery tomorrow then I'll report back - thanks.
Old 06-19-2013, 03:38 AM   #4
I suspect you battery has a short within. Inside battery itself.
goody59 is offline   Reply With Quote
Old 06-19-2013, 06:00 AM   #5
Herk7769's Avatar
DEAD does not mean no voltage or the inability to produce current.
A "dead" battery is any "12 volt" battery with less than 10.5 volts.
I would look at what is on the 20 amp fused circuit.
What is written next to it?
HAM CALLSIGN - KC3FFW
Old 06-19-2013, 11:46 PM   #6
Ok - went to have the battery test at Interstate Battery but they had closed. So, went ahead and purchased a new battery at Costco (figured I'll go out on me soon anyhow), hooked it up to the trailer.
It appears all's well now - I didn't open the pop-up yet to test all the accessories, but when I put the new fuse in the WFCO showed green and when I plugged in shore power the fuse didn't immediately blow.
So, seems a bad battery can cause this particular fuse to blow but I'll open up the camper tomorrow to make sure everything's okay before I store it until our Labor Day trip.
Speaking of batteries, will this battery run my pop-up for 3 days on its own? I've never tried it as my sole power, but I'm thinking it can do it. I can run the fridge on propane, and use the camper heater sparingly overnight as long as our two heated mattresses aren't too much of a drain.... what do you think? I really don't want to buy a generator for 3-4 day trips on 12V.
Old 06-20-2013, 02:06 AM   #7
Denver, CO
garbonz's Avatar
Need information on the batteries AND on what the mattress heaters draw, but unless you are really careful, probably not. Many posts on this but a typical single deep cycle is really only good for one day, if you expect it to last.
2017 Fuse 23T
Old 06-20-2013, 04:15 AM   #8
Are the heated mattresses 12V? Mine are 110V only and will only work with shore power.
2012 F350 Lariat CC SRW 6.7L Powerstroke
pwrstroke2012 is offline   Reply With Quote
Old 06-20-2013, 08:04 AM   #9
HONDAMAN174's Avatar
Ditto. I pondered the question of purchasing an invertor to power heated mattress. After many inputs and math calculations, decided not worth the expense for an invertor and the additional two batteries have to add to the pair I use.
Just glad to get away
Old 06-21-2013, 01:33 PM   #10
ok - so my battery I purchased was a Kirkland Marine/RV Deep Cycle battery, Group 27DC, 115 Amp hour, 750 Marine Cranking Amps, 600 Cold Cranking Amps.
Seems like a strong battery to me. The mattresses say 120V only so I guess I can't run the mattresses w/o a generator or shore power - but that's a little odd b/c I plug the mattresses into my outlets on the camper. But I suppose my battery doesn't actually run these outlets I guessing.
Our next trip is at 8500 ft. elev. with no shore power, so I'm wondering how long I can expect this battery to power occasional ceiling dome lights - probably use for a few hours each night AND my heater occasionally at night (since I can't use the heated mattresses)?
I'm thinking my built-in heater draws a lot of power. I can fire up the fridge on propane once we get settled or just use a cooler. Can I make it 3 nights with occasional heater use at night and interior lighting? If not, I guess it's essentially tent camping which ain't so bad I suppose! lol! Thanks!
