Old 07-13-2018, 12:14 PM   #1
No power to 110 outlets
Just bought a 2013 Rockwood Freedom 1910 pop up. It's our first trailer.
Just took it out and set it up. There's power going to the interior roof lights and fan, but nothing to the power outlets, interior or exterior.
I'm plugged into the 120v power onsite, but I'm not sure if the power's coming from there or the battery.
I know the dealership power washed the tent trailer before we got it, so they may have tripped the GFCI. The outlet say 'GFCI Protected', but none of them have the test or reset buttons on them.
I can't locate a fuse box or circuit breakers.
Anybody might know where these might be located???
TIA
New Guy Camper is offline   Reply With Quote
Old 07-13-2018, 01:10 PM   #2
I've got a 2016 Freedom 2318G and its' fuse box is located right in front of the inverter below the sink. Suspect the breaker switch might be switched off. (Just a guess)
dschwerin is offline   Reply With Quote
Old 07-14-2018, 05:12 PM   #3
Lights and Fan run on DC..........The outlets are AC.........check the breakers in the power panel. Also check GFIC on the outlet.
Trevor43 is offline   Reply With Quote
Old 07-15-2018, 09:10 AM   #4
SeaDog's Avatar
welcome to the forum its a great place to get your questions answered. as you can see good luck let the forum know if that fixes the problem.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 07-15-2018, 09:29 AM   #5
wmtire's Avatar
Since you stated this is your first trailer, then this thread may help you understand an RV's electrical systems and many other things. We put it together for newer campers.
New to RV's helpful hints
2011 Flagstaff 831 RLBSS
I hate it when people don't know the difference between ur and u'r!
Old 07-15-2018, 09:40 AM   #6
Mr. Dan's Avatar
Every time I’ve seen dead 110v outlets after water intrusion (trailer or house), I’ve found the master GFCI outlet tripped. Look at every 110v outlet and find the master with test and reset buttons (maybe in bathroom; I don’t know your unit) and press the reset button. If it trips immediately, you MIGHT still have water in an outside outlet.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 0; booked = 14
power
