Old 04-28-2013, 07:00 AM   #1
wayne in florida's Avatar
Lightbulb No Power to 12v inside lights. Roof only
Can't seem to get the lights on inside. Both buttons pushed under stove to activate.???????
wayne in florida is offline   Reply With Quote
Old 04-28-2013, 07:02 AM   #2
Sorry I have a MAC BR28TSC
Old 04-28-2013, 07:03 AM   #3
Professional Texan
TexasBob's Avatar
Please post the make and model of your RV. There will be owners of the same RV that can help you best. ... and check your fuses.
Texas Bob
2015 Chevrolet Silverado HD2500 Z71
2013 Prime Time Tracer Executive 2640 RLS
TexasBob is offline   Reply With Quote
Old 04-28-2013, 07:59 AM   #4
When I had a Fleetwood popup, there was a switch that was activated when the aft bed was fully extended. That switch (or the metal sheet that was supposed to move it) was quite temperamental. I was told that this was a safety feature to keep power off of the RV when it wasn't opened up. Perhaps that's what's wrong here.
(And two switches you've turned on? Isn't one of those for the fresh water pump?)
Old 04-28-2013, 10:20 AM   #5
First, check the fuses. Should be a LED showing beside the fuse if it is blown. Should be 2 wires going up beside the strut near the power panel. Make sure that the connector is not disconnected or that the wires have been pinched/cut.
Jarhead71 is offline   Reply With Quote
Old 04-28-2013, 12:55 PM   #6
Found it.....Bad wire nut.!!!!
