Originally Posted by D Porter
Noted. The ground looks good inside the TV (grounded to the body) but I'll try to find a better spot.
Thanks again guys.
Do you have a continuity or resistance ohm tester on a meter? You need that. Touch the ground pin on the vehicle plug to a good ground on the vehicle, say a body bolt with no paint. It should be just a few ohms, if that. Do the same on the trailer. I am thinking one of those is bad. Could be the wire or where it is attached, but something is not right.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -
18
Come read my
Camping Blogs
