Old 05-23-2013, 11:06 PM   #1
No Trailer Lights
Hey guys,
Just got our '06 1640 out of storage and the trailer has no running lights, blinkers or brake lights. As far as I know they were working when I parked the camper.
I used an aftermarket wiring harness since our Rav didnt come with a tow package. The fuse at the Rav battery is good, and the plug has power to all prongs. Seems like the issue is in the trailer?
Any tips?
Thanks in advance.
Dan
2006 Rockwood Freedom 1640
8Ft box
2007 V6 RAV4
Totally new to this pop up camping thing....
D Porter is offline   Reply With Quote
Old 05-23-2013, 11:20 PM   #2
Engineer of Crazy Train
ChooChooMan74's Avatar
1 bad ground
2 mice
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 05-23-2013, 11:49 PM   #3
bikendan's Avatar
something's wrong between the trailer connector and your Rav's harness.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 05-24-2013, 09:41 AM   #4
I did a quick check of the ground and looked for mice damage but I didn't see anything obvious. I used connector grease to connect the trailer to the Rav harness. Im not sure what else to try?
Thanks for the replies.
DP
8Ft box
2007 V6 RAV4
Old 05-24-2013, 10:00 AM   #5
daydreaming about camping
jeeplj8's Avatar
I will echo above, sounds like mouse damage.
In order to diagnose, you need to isolate each possible cause. What I would do is make a small jumper from a 12 volt battery (I have found that a lawn tractor battery works great for these kind of things and is handy to have in the garage) with a clip to the battery on one end and a terminal plug on the other. plug it in to each terminal on your camper plug and look for effect. If still no light, you know the problem is in the camper wiring.
It could be damage to the plug itself, that happens. Or a ground problem.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 05-24-2013, 03:19 PM   #6
Alright,
I ran a wire from the positive side of the trailer battery and connected it to each prong of the trailer connector. Bingo, we had power to each light when connected. So the issue is indeed with the TV. The inline fuse off the TV battery is good. Got any other tips?
Thanks for the idea jeeplj8.
8Ft box
2007 V6 RAV4
Old 05-24-2013, 03:27 PM   #7
Could be some corrosion in one connection or the other. Maybe some contact cleaner or diaelectric grease may help.
RickV is offline   Reply With Quote
Old 05-24-2013, 03:48 PM   #8
What about the ground on the TV?
Locomotive Engineer
Old 05-24-2013, 05:09 PM   #9
jeeplj8's Avatar
Originally Posted by D Porter View Post
Alright,
Do you have access to a volt meter or test light? They are fairly inexpensive and should be part of every campers tool kit.
My suspicion is something wrong with your plug. You need to check for power in the wires going into the plug from the tow vehicle.
Old 05-24-2013, 09:22 PM   #10
It's pulling .5 of a volt at the TV connector.
Have this harness: Curt T-Connector Vehicle Wiring Harness with 4-Pole Flat Trailer Connector Curt Custom Fit Vehicle Wiring C55307
and this adapter: Adapter 4 Pole to 7 Pole and 4 Pole Hopkins Wiring 37185
Thanks again.
8Ft box
2007 V6 RAV4
