Old 06-13-2016, 07:30 AM   #11
Kayak Roof Rack
Hi Goff,
Thanks so much for the pictures--that helps a lot. If I'm interpreting them correctly, it looks like you have bolted an "L" bracket to the bottom and made that your load-bearing component; however, I also know that you have support pieces that run parallel to the edge of the roofline. It looks like those rest on the edges of the roof, but I'm not sure how much load they're supporting. Thanks in advance for any clarification!
bikesalot1 is offline   Reply With Quote
Old 06-13-2016, 04:57 PM   #12
Pup roof rack
There is no weight on the roof except for side to side which is very little. The angle brackets on the frame are bolted on. The vertical pipe lengths are cut so there is no weight on the roof.
2016 Flagstaff 23 FB, GVWR 5385
Tundra, Double Cab, 5.7
TRD Off Road 4x4, GVWR 7200 lbs.
w/ tow package
MS Gulf Coast
Goff is offline   Reply With Quote
roo, roof
