Old 07-27-2018, 09:59 AM   #21
Grammar Pedant
67L48's Avatar
Originally Posted by KMANUEL74 View Post
Not to hijack the thread, but I will. [...]
There's a name for people like you and a place we wish you would go. Yours is a good question and one that would serve well to ask on its own, in its own thread.
As for the OP, I ran one of these in my PUP for years. My model was a Fleetwood Utah that had the slide-out dinette. On either end were the factory light fixtures. In the middle, right at the dinette, was just a little 12VDC pod. We had one of these that fit in and snapped to the pole that held out the slide-out roof/fabric.
The light worked as well as the ends. The fan was just OK. We would occasionally put it on a bunk end during nap time to move some air in the hot afternoon. I never felt like the fan moved much air relative to the noise. It wasn't terrible, but it wasn't amazing, either.
Definitely worth having and I'd easily pay $25 to get one if I didn't have one.
Good luck.
Former RV: 2018 Rockwood Mini Lite 2504S
67L48 is offline   Reply With Quote
Old 07-27-2018, 11:32 AM   #22
Thanks for the input! I'm not too concerned with the noise because we will always have our 5 y/o twins with us who still sleep with a lot of ambient noise in their room (fans, window AC, or a sound machine. So the hum of the fan is actually welcomed. I also like the idea of the light, because with the curtain closed on the bunk end, the dome lights in the main cabin are of little use, so it's an added bonus.
I think I'll "splurge" for these...even if they're mediocre at best, it's the better alternative to a separate light AND a separate fan, neither of which will plug in to the factory dome.
Thanks everyone!
"You cannot learn what you think you already know." -
"The difficult we do immediately; the impossible takes a little longer"
User Banned is offline   Reply With Quote
Old 07-28-2018, 10:19 AM   #23
Originally Posted by User Banned View Post
Are your bulbs LED or incandescent?
PCB with LEDs mounted in a line. Looks like the whole board would have to be replaced unless you're handy with soldering and can find the LEDs online.
These were ordered in April 2018. The part number on the dealer Work Order is 10-23192A.
Here is a picture of the light & power plug...
1993 Coleman Destiny Royale
2017 Rockwood Freedom 2318G
2006 Toyota Highlander Hybrid Limited
2011 Toyota Highlander LE
2015 Toyota Tacoma TRD Sport 4x4 4LV6 DBL LB
nemolomen is offline   Reply With Quote
Old 07-29-2018, 11:19 PM   #24
They are a bit noisy, and since they plug into the lighting circuit, you must turn on the main light switch, then turn off each light individually. Otherwise, you probably won't find much that's better.
Jim & Renee
2020 Jayco Jay Feather X-213
Every weekend boondocking in the National Forests or at Lake Vallecito.
jimmoore13 is offline   Reply With Quote
bunk, fan, light
