Old 06-08-2009, 07:41 AM   #1
Optimum Hitch Height
Have used our 206ST twice already but seems to be too low at the hitch. Can anyone help with the optimum hitch height to carry the load efficiently?
Thanks for your help.
Mrchipps
New Hampshire
mrchipps is offline   Reply With Quote
Old 06-08-2009, 09:11 AM   #2
It's whatever makes the trailer level when hitched. Very important for tandem axle trailers.
turbopuppy is offline   Reply With Quote
Old 06-09-2009, 11:58 AM   #3
hunt4240dw's Avatar
Send a message via MSN to hunt4240dw
First have your TT on level ground with level. Then measure the height from the ground to top inside of the hitch. ( Mine is 21 1/2 ). TV on the same level ground with a full tank is 22 1/2. This means I have a 1 in difference. Since I have an average suspsion and a loaded tongue of 750, I should have a difference of 1 5/16. But can not get just another 1/2 ball lift. If turn the shank over, I will gain an 1 1/4. I fugre it better to be on the low side for now. I plan on buying Timbren load bearing bump stops to help.
This is from Equal-i-zer install:
For example: Trailer coupler measures 18”. Loaded tongue weight is 800 lbs. For installation on a ĺ ton pick-up truck, set the ball height to 19” because 1/8” X 8 = 1” above coupler height.
Use this table to calculate additional rise needed for hitch ball.Loaded Tongue Weight in lbs.
400 500 600 700 800 900
Stiff 1/2 5/8 3/4 7/8 1 1‑1/8
Average 3/4 15/16 1‑1/8 1‑5/16 1‑1/2 1‑11/16
Light 1 1‑1/4 1‑1/2 1‑3/4 2 2‑1/4
1,0001,100 1,200 1,300 1,400
Stiff 1‑1/4 1‑3/8 1‑1/2 1‑5/8 1‑3/4
Average 1‑7/8 2-1/16 2‑1/4 2‑7/16 2‑5/8
Light 2‑1/2 2‑3/4 33‑1/4 3‑1/2
This chart is intended as a guide and works for most applications. Depending on your tow vehicle and trailer combination, further adjustment may be needed.
David
The Hunts
2012 F150 Ecoboost, 3.55, tow package
Equal-i-zer Hitch
2009 Flagstaff V-Lite 30WRLS
1982 16' Glastron Ski boat
hunt4240dw is offline   Reply With Quote
Old 06-09-2009, 01:20 PM   #4
Thumbs up Thank you
Could not have anticpated such a complete response. Thank you for taking the time to put it all together. It is very hlpful.
Ray
Old 06-10-2009, 07:53 PM   #5
firedude01's Avatar
go to reese hitch web site it has all the instructions how to set up your hitch and correct ball hight
firedude01 is offline   Reply With Quote
flagstaff, tent camper
