Old 06-23-2014, 09:14 AM   #1
Outside Grill
2015 Rockwood HW 276. When tring to connect the outside grill the propane hose is not long enough, we had to move the grill on the bracket about 8" to the rear just to connect the hose but then we only got it to light and it acted like it was only getting half gas. flames were flickering. has anyone else ran into this? mounting it using the front bracket closest to the door.
kinma13 is offline   Reply With Quote
Old 06-23-2014, 09:20 AM   #2
TURBS's Avatar
It's possible there's some air in line unless it was a continuous "bad flame"
If it's a RVQ type grill they have a pretty low flame anyway.
But hey I like to cook low and slow.
Old 06-23-2014, 09:56 AM   #3
yeah the air i was thinking so was to worried about that but was thinking if it was that far off maybe i didnt connect the hose but it should be a safty hose so it wont even work if hose wasnt connected right.
Old 06-23-2014, 10:10 AM   #4
TURBS's Avatar
Correct.
Hose wasn't pinched slightly 2 as it?
Old 06-23-2014, 10:30 AM   #5
no and i just checked the other ( rear ) bracket but that puts the grill way to far. calling dealer right now. just seeing if anyone else has ran into this. u would think they couldnt make this mistake. hose must have been missed numbered and for a diff model.
thank you for ur suggestions though.
Old 06-23-2014, 11:07 AM   #6
Kaadk's Avatar
No, they can really be that short. Take a look at my setup:
The Q has to be on the right with the shelf on the left because the hose isnt' long enough to do it the other way around. I probably only have 16" or so of hose available.
There's no use crying over spilt milk, unless it's on your keyboard.
Old 06-23-2014, 12:07 PM   #7
if I use the rear bracket on the trailer its 44" from the hose outlet but hose it only 16 " or so.
