Old 06-11-2012, 03:18 PM   #41
Originally Posted by DGrissom View Post
BTW: I am still trying to find a low cost 10' (or there abouts) extension hose for my grill. Anyone have any recommendations (must be cheap!).
So am I, doesn't have to be super cheap
Len & Cheri is offline   Reply With Quote
Old 06-11-2012, 03:47 PM   #42
May not be the right hose to use, but we used 1/4" neoprene hose from NAPA and just put matching quick disconnects on the ends. Check for leaks with soapy water and have used it for 4 yrs with no problems. For no longer than it is used, can't see the propane damaging it as we turn the gas off after each use at the valve on the underside of the trailer.
Old 06-21-2012, 12:36 PM   #43
daydreaming about camping
jeeplj8's Avatar
I have used out outdoor grill several times, and really like it. I wish that I could find a multi-burner stove that mounts to that same channel to cook outside with. Our old 80's Starcraft had a stove that could be moved outside with the quick connect. searched camping world, ebay etc., have not found one.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 06-21-2012, 02:03 PM   #44
DGrissom's Avatar
Do you remember where you bought the quick connects or sizes? (I've already tried standard air hose quick connects, close, but not a match ).
David and Jo Ann G. (& Kenzie the Sheltie)
Prattville, Alabama
2018 Flagstaff E-Pro 19FD "Phoebe"
DGrissom is offline   Reply With Quote
Old 06-21-2012, 02:28 PM   #45
i do not use ours for the same concerns as yours
SALTY is offline   Reply With Quote
Old 06-21-2012, 02:48 PM   #46
I think I got them at Northern Tool or Harbor Freight. If nothing else, you can get hose connections and just cut the factory hose and splice in your new hose. If you have an inverted flaring tool, you can get a short pc of steel or copper tubing, start the flare on both ends of the tube by bulging the tubing and leave it, sliding the hose on and clamping with the small hose clamps. Make sure you check for leaks.
Old 06-21-2012, 02:49 PM   #47
IT Guru
Send a message via AIM to jsilvius Send a message via Skype™ to jsilvius
We've used the one on our Flagstaff for 3 years now and I cook on it just about every night that we camp. Burgers, Dogs, BBQ Chicken, Pork tenderloin... if I can be grilled I've thrown it on there.
Biggest issue I that I have is setting off the smoke detector every now and then.
I'd love to have a 6"-12" extension so that I can move it to the end of the channel, but I've not had a problem with it yet (knock on wood).
2006 Flagstaff 831FKSS
2005 Dodge Ram 2500 SLT 5.9L Turbo Diesel Quad Cab
1 - DH (me); 1 - DW (Tee); 1 - DS (Jarod, 12)
Nights Camping: 2010 - 15; 2011 - 7; 2012 - 9
jsilvius is offline   Reply With Quote
Old 08-05-2012, 01:36 AM   #48
This was not cheap, but it was plug and play for my RVQUE. Moves the RVQUE about 18' feet from my tent trailer (including the 3' of hose that comes out of the trailer). You can purchase different lengths of hose for your needs.
Purchased Mr. Heater F271474 15' Propane Appliance Extension Hose Assembly with 1/4" Male Pipe Thread x 1/4" Female Pipe Thread for about $30 and Mr. Heater F276181 Propane or Natural gas 1/4" Quick Connector Set with Shutoff Valve and Excess Flow Plug for about $25.
2012 Chevrolet Silverado 1500 Crew LTZ 4x4
2013 Rockwood HW276
Tecate is offline   Reply With Quote
Old 08-05-2012, 08:59 AM   #49
Thank you. i found hose that fits the grill that came with camper .Now I am trying to find an adapter that will switch rv quick connect to fit a 3 burner grill i bought. Not haveing good luck
rdallas5xpj is offline   Reply With Quote
Old 08-09-2012, 09:55 AM   #50
FreedomTracker's Avatar
FYI... Sam's Club has SS portable table top grills for $99.98. Better than paying over $200 from the RV stores...
2012 Ford F150 4x4, 5.0L, 3.55
2011 Rockwood MiniLite 1809s
E2 WDH 600/6000lbs
FreedomTracker is offline   Reply With Quote
