Old 08-20-2012, 06:01 AM   #11
Thanks everyone.........worked out well this weekend at Nautral Bridge Station.......needs some soft rubber on the support arm so that it doesn't mess with the decals on the camper side.
Trevor43 is offline   Reply With Quote
Old 08-20-2012, 07:11 AM   #12
trudinator's Avatar
Originally Posted by Trevor43 View Post
I'm using mineral oil to keep it sealed.......that should keep it weather resistant.
Yes, mineral oil would keep it "resistant" to water from normal indoor use, but I'm not sure I would trust just mineral oil for an exterior application, especially since you appear to have a face grain board and not end grain. I'd put it away when it rains. Just MHO.
2012 Rockwood 8293RKSS
trudinator is offline   Reply With Quote
Old 08-20-2012, 08:46 AM   #13
Rugged Brown's Avatar
I would be interested in seeing a pic of the underside to see what hardware you recycled from the old table. Your new table looks quite a bit bigger than my old table and I wonder if the recycled hardware will work.
thanks
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 08-20-2012, 09:50 AM   #14
It is just the 11" rail part and the fold down arm for support. I had to sandwich two 1/2" pieces of marine plywood to make a 1" thick piece. Diminsions were 11" x 7.25" for the piece that holds the hardware. The cutting board is wider than the table I got and an inch shorter.....14 x 22" is the cutting board.
Old 08-20-2012, 09:56 AM   #15
Triguy's Avatar
You did a really nice job. Looks great.
Like your experience, the particle board on my table is falling apart.
This thread is going into my "mods for the winter" file
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 08-20-2012, 08:05 PM   #16
Threegeeks
We learn the hard way, same problem. Since we are not very handy, we are going to attempt to order some new one.
Jeff, Cindy + one kid and two dogs
2012 Rockwood A124
2007 Toyota 4Runner SR5, 4WD, Tekonsha P3
U.S. Army Veterans
threegeeks is offline   Reply With Quote
Old 08-21-2012, 10:17 AM   #17
Looks great and it's a cool idea. It appears to be made of hardwood. Most hardwoods can handle moisture from time to time. If you really want to put something on it, I would NOT use ordinary mineral oil, polyurethane, or any such coating. Use a butcher block oil, beeswax, etc. John Boos makes a bunch of such products. You can buy them online or at stores like Sur La Table.
2006 Ram 2500 CTD
2011 Sabre 31RLDS
awjoker is offline   Reply With Quote
Old 08-21-2012, 10:22 AM   #18
trudinator's Avatar
Butcher block oil is MOSTLY mineral oil, with an additive of walnut oil or citrus oil to make it smell good. While I agree that beeswax will protect it somewhat, it won't protect your board from rain. Face grain boards can and will warp from continued exposure to moisture. Best scenario is to keep it stowed when not using it.
Old 08-21-2012, 10:27 AM   #19
True......I would never leave it out it in the rain again.........but under the awning and being outdoors......mineral oil should surfice. I doubt I would even use it as a cutting board. Thanks for all of the nice replies and comments.
