08-12-2012, 06:37 AM
Outside Table
On our last camping trip I learned a valuable lesson......the small outside table that mounts on the rail does not like being left outside during a torrental down pour. Once the rain stopped, I went out side and the particle board it uses had swelled up to about 3 times it's normal size. So after the normal mental ass kicking I gave myself......I decided to chuck the table and was going to buy another. About an hour later I went and dug it out of the trash and removed all of the hardware and decided I would build another. A few days later I thought about using a butcher block to make the table out of and came up with this.....
08-12-2012, 06:51 AM
"On the road again"
Looks great - a couple of good coats of marine varnish should protect it from most all elements and give you great service.
Robert & Estha Shiflet
Georgetown XL 378TS
Jeep Gladiator Willys Tow Vehicle
08-12-2012, 06:52 AM
I'm using mineral oil to keep it sealed.......that should keep it weather resistant.
08-12-2012, 06:57 AM
"On the road again"
Yes it should.
Georgetown XL 378TS
08-12-2012, 08:46 AM
Very nice! Great solution!
2012 FR Flagstaff T12SDTH
1996 Shadowcruiser Pop Up Truck Camper
1967 Newell Motorcoach
2003 Ford F150 5.4 V8 Triton Super Cab
2004 Nissan Titan LE 5.6 V8 4x4 Crew Cab
08-12-2012, 09:38 AM
For those that may no know: Be sure u use food grade mineral oil.
Jeep4Two
2011 FR Rockwood Premiere A126 Hard Side
TV=2011 Jeep Wrangler Sahara 2 Dr
Reese 66065 WDH, Curt WDH Shank #17120
Prodigy P2 Brake Controller, Mopar 7-pin Harness
B&M Transmission Cooler (#70268)
08-12-2012, 03:48 PM
GREAT mod!!!!
...and...we're camping!!
Glenn & Debbie
2013 Rockwood A127TH (aka Carl)
2012 Ford Raptor
Camping born-on date: 21 July 2012
Nights camped: 2014-3 (so far!!); 2013-16; 2012-2 nights
08-12-2012, 03:58 PM
Looks good.
I had something similar on my flagstaff tt.
Used the same mount as my rvq grill.
08-19-2012, 02:09 PM
I like it. Good Job.
Politicians should be required to wear uniforms like NASCAR. At least the TAXPAYERS would know who their corporate sponsors are !
08-19-2012, 03:09 PM
TeresaInCAL
Nice!
Teresa
2013 f150 Ecoboost 4x4
2009 Gray Wolf, 22BH
08-20-2012, 06:01 AM
Thanks everyone.........worked out well this weekend at Nautral Bridge Station.......needs some soft rubber on the support arm so that it doesn't mess with the decals on the camper side.
08-20-2012, 07:11 AM
Yes, mineral oil would keep it "resistant" to water from normal indoor use, but I'm not sure I would trust just mineral oil for an exterior application, especially since you appear to have a face grain board and not end grain. I'd put it away when it rains. Just MHO.
2012 Rockwood 8293RKSS
08-20-2012, 08:46 AM
I would be interested in seeing a pic of the underside to see what hardware you recycled from the old table. Your new table looks quite a bit bigger than my old table and I wonder if the recycled hardware will work.
thanks
Terry/Bernadette Lily the Yorkie 2019 Dodge Ram Sport 1500 2019 FR Vibe 28RL
08-20-2012, 09:50 AM
It is just the 11" rail part and the fold down arm for support. I had to sandwich two 1/2" pieces of marine plywood to make a 1" thick piece. Diminsions were 11" x 7.25" for the piece that holds the hardware. The cutting board is wider than the table I got and an inch shorter.....14 x 22" is the cutting board.
08-20-2012, 09:56 AM
You did a really nice job. Looks great.
Like your experience, the particle board on my table is falling apart.
This thread is going into my "mods for the winter" file
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
08-20-2012, 08:05 PM
Threegeeks
We learn the hard way, same problem. Since we are not very handy, we are going to attempt to order some new one.
Jeff, Cindy + one kid and two dogs
2012 Rockwood A124
2007 Toyota 4Runner SR5, 4WD, Tekonsha P3
U.S. Army Veterans
08-21-2012, 10:17 AM
Looks great and it's a cool idea. It appears to be made of hardwood. Most hardwoods can handle moisture from time to time. If you really want to put something on it, I would NOT use ordinary mineral oil, polyurethane, or any such coating. Use a butcher block oil, beeswax, etc. John Boos makes a bunch of such products. You can buy them online or at stores like Sur La Table.
2006 Ram 2500 CTD
2011 Sabre 31RLDS
08-21-2012, 10:22 AM
Butcher block oil is MOSTLY mineral oil, with an additive of walnut oil or citrus oil to make it smell good. While I agree that beeswax will protect it somewhat, it won't protect your board from rain. Face grain boards can and will warp from continued exposure to moisture. Best scenario is to keep it stowed when not using it.
08-21-2012, 10:27 AM
True......I would never leave it out it in the rain again.........but under the awning and being outdoors......mineral oil should surfice. I doubt I would even use it as a cutting board. Thanks for all of the nice replies and comments.
