Old 08-28-2014, 04:07 AM   #21
ARLO
Nice setup.
rlocicero is offline   Reply With Quote
Old 08-28-2014, 04:13 AM   #22
W4NT3D's Avatar
Thank you.
2015 Rockwood HW296
2014 Silverado 1500 LTZ
W4NT3D is offline   Reply With Quote
Old 08-28-2014, 06:50 AM   #23
vinmaker's Avatar
The nearest HW296 I could locate was in MD. Close to 1,000 miles away. That was too far for me to go. I had to place an order for it. Hence I am in the position I am.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 08-28-2014, 08:16 AM   #24
papasmurff1's Avatar
I traveled to get mine as well. I went from Memphis to Chicago but it saved me around $7000.00 and dw and I got a nice vacation and our first campingtrip on Lake Michigan.
papasmurff1 is offline   Reply With Quote
Old 08-28-2014, 08:30 AM   #25
My wardrobe sits above the counter top as well. As far as the height of the ceiling I did have to stop and get a step stool for dw so she could reach the ac controls. Lol the ceiling is high so you do not get a cramped feeling at all.
Old 08-28-2014, 08:33 AM   #26
Congratulations! Enjoy!
brewjaz is offline   Reply With Quote
Old 08-28-2014, 10:26 AM   #27
W4NT3D's Avatar
Thanks for all the congrats on our new PuP. Setting it up yesterday I started to look through all the literature and brochures. So far I noticed two things; one being the right rear stabilizer leg is bent. It was very difficult to turn the provided wrench to open the stabilizer to make the base make contact with the ground. The stabilizer base isn't even level when it makes contact with the ground. I think the stabilizer was put on incorrectly. The second thing is the Fantastic Fan works fine, but it doesn't seem to work when I turn the overhead light switch to the off position. I couldn't figure out why it wouldn't work from turning it on from the actual fan switch. I could be doing something wrong, but I cant imagine you would have to turn the light switch on, manually go around and turn off all the lights to have the fan work while sleeping. I can't wait until I get home tonight to play around with it some more.
Old 08-28-2014, 10:47 AM   #28
GalsofEscape's Avatar
[QUOTE=Tactical Patience;689607] the Fantastic Fan works fine, but it doesn't seem to work when I turn the overhead light switch to the off position. I couldn't figure out why it wouldn't work from turning it on from the actual fan switch. I could be doing something wrong, but I cant imagine you would have to turn the light switch on, manually go around and turn off all the lights to have the fan work while sleeping. I can't wait until I get home tonight to play around with it some more.[/QUOTE
are you talking about the master switch that turns off all the lights? yes the fan is on it. that is a master switch to ensure those items are off or remain off when you lower the roof. that way you have nothing on when the camper is closed. it is a safety feature.
we use the individual light switches while camping, not a issue at all as we usually only have one or two lights on at a time anyways.
Nice unit, have many nice trips in it.
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Bruce" 2011 Dodge Durango V8 Hemi Crew
Just us gals (me, Sis and our daughters)
We spend alot of money to go sit in the woods
GalsofEscape is offline   Reply With Quote
Old 08-28-2014, 11:04 AM   #29
galsofescape i have a hw276 but im sure the switch is the same it sounds like. yes that switch is a master power switch that kills power to everything,(well almost) my fan, lights and water pump and the inverter are turned on or off by this switch, but the radio and fridge are not.
kinma13 is offline   Reply With Quote
Old 08-28-2014, 11:16 AM   #30
Kingman, I do not think my water pump is on that switch, will have to see. Would not be to surprised if it was, but am surprised that your converter is. mine is definitely not on that master switch as the converter charges the battery when I am home, closed up but plugged into shore power.
hw296, rockwood, pop up
