Originally Posted by PUPJake
I need a new bag awning and my research found 3 manufacturers: A&E Dometic, Carefree, and Shademaker.
The Carefree seem really expensive.
Shademaker legs only seem to attach to their own brackets on the frame and only if you get the SupremeXL version.
Dometic legs only rest on the ground? All the pictures show them on the ground. I'm new to PUPs and it looks like there are black brackets on the side of the camper so I'm wondering if the legs can attach to those brackets (black with a round hole).
What do you recommend and where should I purchase your recommendation? I don't necessarily want the cheapest, I want the sturdiest, best value.
Dometics have ball & socket mounts for the side of the camper. The horizontal poles that hold the awning away from the camper body must use these. The upright legs have removable rubber caps, complete with tent-stake hold-downs, that can be removed to reveal the ball end. A socket can be screwed to a low point on the camper body.
I highly recommend using the vertical approach, because the pole can be staked in place, and you can use parachute cord tied to the upper awning frame and anchored to a second tent stake to brace and tension the awning to withstand quite a bit of wind. Furthermore, it's far easier to dodge a vertical pole than it is to duck around a pipe going at a 45 degree angle from the awning to the camper body. Finally, even without the additional tie-downs, the setup is far more robust in the wind.
Regardless of how you use the awning, get some spare sockets. The sockets are fragile, but they are also inexpensive. If you break one in the field and you have a couple of spares, there are just two screws to remove and replace to put you back in business.
I've learned the hard way that these awnings are not very sun tolerant. My 2014 awing "bag" is falling apart, because UV rays destroyed it. Most roll-up awnings offer a way to cover the closed awning, but it's hard to imagine a way to cover the "bag." I now use an RV cover to protect the whole camper, and I use tire covers to keep the tires out of the sun. I will have to replace my perfectly good awning or replace the "bag" this year, because the joint between the bag and the rail is disintegrating.
