Old 01-02-2015, 03:56 PM   #11
phillip252's Avatar
I will be ready for next winter, I will be doing some camping on into November.
phillip252 is offline   Reply With Quote
Old 01-29-2015, 05:18 AM   #12
gizmo
Thanks again to the idea I got here about using emergency space blankets on the bunk ends of my popup...got them from Cabelas. They are good quality and easily secured with bungees. The reflective material from Lowes was also "cool" to use on the windows. Very much helps against the sun/heat here in Florida, and as was stated, provides privacy too. Used them last summer, effective at keeping debris off the bunks as well. Held up pretty well in stiff breezes. Standard equipment now on my pup along with bunk end fans. Thanks also to the suggestion to change out standard bulbs for LED's, this has also helped cool the interior and reduce electrical consumption.
2012 Rockwood 1940ltd
2004 GMC Sierra 4x4
Ringbill is offline   Reply With Quote
Old 01-30-2015, 02:07 PM   #13
Sand D
Talking
I just got my Gizmo's and will try them out next week.
I did not get the velcro sewed into the top edge but want to do that myself.
How did you attach the velcro to the trailer, I have the HW 29SC?
Do you need velcro to run the entire edge of the gizmo or can you attach in segments?
Sand D is offline   Reply With Quote
Old 01-30-2015, 04:01 PM   #14
phillip252's Avatar
I cut my Velcro into 2 in strips and spaced them equally apart, I used the 3m kind and then stapled it, if you use the Velcro make sure you move Velcro down to the weather striping and on the gizmo even with edge.
Old 01-30-2015, 04:51 PM   #15
Camper
New to popups ... Stapled ... Scares me ... Stapled into what?
Rockwood Ricky is offline   Reply With Quote
Old 01-30-2015, 05:16 PM   #16
phillip252's Avatar
I have a Rockwood popup and installed the Velcro to the inside of the roof front and back , I will try to get some pictures for you.
Old 01-30-2015, 08:52 PM   #17
f5moab's Avatar
The underside of the top is wood. I just ran the velcro on the wood and used a staple gun to staple about ever six inches. I used a full length of velcro. Has been ok for almost two years.
And in my case, velcro was necessary. First time I tried the gizmos on a windy day I gave up after about twenty minutes. Sent them back to have velcro sewn in, and never looked back. But I'm a single camper. If there were two it would probably would have been better.
f5moab is offline   Reply With Quote
Old 01-31-2015, 09:08 AM   #18
phillip252's Avatar
Thanks f5moab for cleaning that up for me. Lol
Old 02-02-2015, 11:46 AM   #19
vinmaker's Avatar
I have not installed the velcro on the pop up yet but plan on stapling it across the top also. I will not even try to use sticky stuff. Just gonna staple it an be done with it.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 02-02-2015, 12:13 PM   #20
Camper
How many inches from the lower edge is best to staple the Velcro?
pop up
