Sounds like you have either a loose or a corroded connection, if there are no blown fuses. You may have to remove the power converter, and check the wiring going to it carefully. Also, a wire could have gotten pinched where the lift mechanism goes up and down, and the wire inside the plastic sheathing could be broken. Had that happen on my94 Coleman pop up before. Hope this helps! Randy
