Old 12-06-2012, 12:35 AM   #1
Pop Up Roof Stuck - weird clicking sound from motor
I hope someone can help me figure this out. I have a 2012 rockwood freedom 2280. I just got it 2 weeks ago used so no warrenty
I flip the switch to raise the top and it moves about a inch and then loud clank clank noise from the switch area motor. Any ideas what my problem is? And dang it the hand crank is under the matress inside
femetal1 is offline   Reply With Quote
Old 12-06-2012, 08:00 AM   #2
Herk7769's Avatar
Is your battery fully charged?
HAM CALLSIGN - KC3FFW
Old 12-06-2012, 09:11 AM   #3
Flagstaff 625D Popup
I had the same problem with my 625D.
It turned out that the motor mounting bolts were loose and the gears where slipping causing the noise.
I pushed the motor over so the gears were tight together and tightened the bolts. That fixed it for me.
Bean
bean is offline   Reply With Quote
Old 12-07-2012, 01:32 AM   #4
Battery charged yes and the motor was loose I tightend the motor and that made the manual crank work but now I have NO power to the elect crank. I checked the 20 amp fuse behind the propane tank and checked the breakers. I'm stumped
Old 12-07-2012, 07:15 AM   #5
Head Rambler
Look for fuses near the motor. Also when tightening the motor back down you may have pinched a wire or pulled a plug loose. Look at the motor and see if you see anything.
Gotta go campin!
Old 12-07-2012, 03:15 PM   #6
No all fuses are ok and no wires pinched or unplugged. I replaced the circut breaker today with a new one and still no power. I think I broke the motor. Anyone know where to purchase just the motor from or have the one I have rebuilt?
Old 12-07-2012, 06:23 PM   #7
Another rat in the race
jar3316's Avatar
Loosen the motor back up and see if it moves when you supply power, you might be slightly off on your roof and causing the motor to stop due to not enough power to push past the alignment issue. Or you could have bolted it in to tight and the gears are binding. Also look for a breaker button on the motor.
even with the big motors we use at work they are hardly worth rewinding I would look into a new one. look at the spec plate and find the motor through a motor supply house, it will be cheaper than through the dealer. They might even be able to put you into a stronger motor for same or not much more money.
A rainy day camping is better than any sunny day at work
2004 F250 V10 SD Xcab 2011 Wildwood T26BHXL
jar3316 is offline   Reply With Quote
Old 12-07-2012, 06:28 PM   #8
jar3316's Avatar
Forgot
check for power at the motor when you flip the switch, you could have burned up a switch, connection, or wire. Motors will pull (in theory) and infinite amount of power to turn, that is until you beak the weakest link (i.e. fuses in a best case scenario).
Old 12-07-2012, 08:00 PM   #9
HONDAMAN174's Avatar
Check the wires to the switch. So little slack in mine that I could see a wire or contact breaking off at the switch.
Just glad to get away
Old 12-10-2012, 02:20 AM   #10
Does anyone know a place besides the dealer to get the p55000 lift motor from? They want over 300 for it at powerwinch. I can't believe I'm having this problem after not even owning it for little over 2 weeks and it's a 2012 and no I don't have warrenty I got it used :-(
