Old 07-06-2013, 08:26 AM   #1
Popup Electric Winch Motor Repair
If some of you have experienced failure of your popup electric winch (Carefree 55000), maybe this will help. I assume you know about the backup 7/16" bolt head embedded in the grease on the motor side of the winch. Note that is ONLY a 1/4" bolt and will shear off instantly if your motor is frozen, so before using your powerful drill on it, make sure it will turn. You don't have to make your own mistakes: learn from mine.
First, a description. This winch has a small electric motor with a small worm gear screwed onto the upper end of its shaft and spot welded to keep it in place. That worm gear meshes with the winch large gear and turns it, raising or lowering the camper top. The other end of the worm gear has the 1/4" bolt with the 7/16" hex head screwed into the worm gear and spot welded to keep it from unscrewing. Thus, when you turn that bolt with your drill or other means, you are turning the motor shaft and are operating the winch either up or down.
My motor was ineffective before becoming frozen. Would not raise the top very far, but then over the winter it froze up completely. Thus, in a bind, I had to do something. I ordered a new winch but needed to set up the camper for incoming family. So I took off the motor, disassembled and cleaned it, and solved my problem. You'll probably want to scoop out as much of the grease as possible at the top end of the motor, and note the metal bracket held on by the motor mounting bolts is necessary to hold the grease.
1. Two long 1/4" bolts hold the motor to the winch frame and also hold the motor ends together against the motor's mid-section, which is just permanent magnets. You can see these after getting all the grease out.
2. Remove the two bolts and disconnect the two wires, noting where/position of attachment of these wires. Mine connected with 2 other wires (mismatched colors) with small bolts and taped connection.
3. Mark the position of both ends of the motor relative to the mid-section, and then separate the bottom motor end from the mid-section. This is most likely where your problem is. I had to put penetrating lube on mine to get the shaft to come loose from the bearing on this section.
4. Clean all the gunk and goop and dirt and whatever out of the motor's end. The brushes are in this and need to move freely so they will contact the armature.
5. The armature is on the back end of the shaft and needs to be cleaned down to the copper. It's most likely black with corrosion and crud. Try to get it cleaned smoothly down to the copper so the brushes make good electrical contact. Note: you can pull the shaft out of the midsection, but it will resist due to the strong magnets in the mid-section.
6. Once it is cleaned, put a small amount of lubricant on the shaft or bearing, reassemble making sure your marks match and the tiny position notch on the ends match the mid-section.
7. Hold it together and reattach to the winch frame with the 2 bolts, remembering to reinstall the metal bracket that holds the grease.. Connect the wires and try it. Worked like new for me...but since I've already received the new winch now I'll swap it out. Be sure to fill it back up with grease if it works good for you.
cessna is offline   Reply With Quote
Old 07-07-2013, 07:06 AM   #2
Incheon, S. Korea
BigBaron's Avatar
I'll have to check the make of mine. Thanks for posting.
Me, Julie, Lil' Barry, Faith, and OSD Fang
2012 Coachmen Clipper 126 - Don't even have a TV anymore.
I don't know when we'll be able to go camping again...
BigBaron is offline   Reply With Quote
Old 07-12-2013, 09:01 AM   #3
I am about to purchase a 2014 Rockwood 2560G and now I am concerned about the lift motor. Do these motors have a history of breaking down? I do not understand the "backup bolt head" and could not do a repair like you described. If the electric ever did freeze up I could still hand crank it correct?
dmullen is offline   Reply With Quote
Old 07-12-2013, 09:56 AM   #4
No, if the motor freezes up you are unable to lift the top--PERIOD. If the motor just "quits" electrically, but the shaft would still turn freely, then with the bolt backup you'd be able to crank it manually...but, evidently it is an "hour long" job (30 min plus I read from some) to hand crank it. I think the motor is 6000 rpm, and takes 30 seconds to crank it up or so...so you'd be cranking by hand 3000 rounds with the crank handle. Therefore, it is recommended that you carry an electric drill with a 7/16" socket. Mine is a 2005 model..bought used, but used very little. I bought the entire winch replacement on Amazon for about $225. After getting the new one which does not have an access hole for the backup in the cover, I'm thinking they may not come with one and you'll have to either remove the cover of the winch or cut your own with a hole saw attachment. Get your dealer to show you. I'm hoping the new winch will last longer than the old one as I am planning to make sure it has enough protection from the dust the tow vehicle will be throwing at it as well as the elements when it is parked. I've had hand crank popups before and never had any problem getting them to work, and don't think it would be a problem with this kind either if it's an option. These are just a bit more luxurious and thus have more bells and whistles, which isn't always a good thing. As far as the elec. winch history, it's only the problems you hear about (like mine). It's made by Powerwinch, and sold by Carefree in Colorado. Some folks may never have a problem with it. I'd be glad to answer any other questions I can help you with.
Old 07-12-2013, 10:58 AM   #5
My winch was not working at all. The battery had good power. It ended up being a fuse underneath the lower pan under the winch. I would have never known it was there if I hadn't found this article. I have a Rockwood Freedom.
http://robertssales.com/articles_tut...ked_winch.html
evo8grl is offline   Reply With Quote
Old 07-21-2013, 03:35 AM   #6
Thank you for that link
zzzzzzz is offline   Reply With Quote
Old 07-29-2013, 02:20 AM   #7
Incheon, S. Korea
BigBaron's Avatar
ditto!
Old 09-15-2013, 06:34 PM   #8
Does anyone know where I could get new brushes or a replacement motor. I have a Flagstaff 425D popup. Jim
Jetfuel is offline   Reply With Quote
Old 09-15-2013, 08:31 PM   #9
Popup Electric lift motor
I could not find one. Checked with Carefree who sells it, and the manufacturer. Both told me no parts are available. I ordered one online off Amazon for a little over $200 w/free shipping. It might be that an electric motor repair shop would be able to get the parts you need. I just think it's pretty lame they don't make available repair parts.
Old 09-16-2013, 04:36 PM   #10
I don't know if this will work on your trailer but it works beautifully on mine. I went to Harbor Freight and bought a 2000 pound atv winch and installed it myself. I have a 176ed. which is probably smaller than yours. The winch comes with all the parts you need to get the job done. Only had to drill six holes. Did it all for under $100.00 dollars. My trailer came with a hand crank winch. You might want to check it out.
mike66 is offline   Reply With Quote
Old 09-05-2015, 01:37 PM   #11
power winch motor is frozen
Cessna,
How did you disassemble your winch motor? My husband cannot remove the worm gear, so he cannot get the motor apart.
CampingTerri is offline   Reply With Quote
Old 09-05-2015, 04:23 PM   #12
f5moab's Avatar
I cannot speak for the new ones, and I cannot speak for other units, but the ones I have had on my 2012 trailer have been problems.
First unit shattered a gear when lowering the roof the first camping trip I went on. Talk about the roof being lowered quickly.
Took it to a dealer, had to pay for the repair, but FR did reimburse me within a week. (Selling dealer was 400 miles away in Denver, so forced to take it over to Grand Junction CO to another dealer for repair. And non-selling dealers only accept cash for repairs.)
From then on, with the new unit (they completely replaced the unit with the shattered gear), the limit switches would go out of adjustment after a few uses. First it was the upper; not hard to readjust, just messy due to all the grease (new power winches do not have the grease problem). Then the lower limit switch started to to out of adjustment. Turned into an every other month ritual. Pull off the over and dive into the grease.
Last camping trip, it started to make a grinding noise; not sure what, but was grateful it held together for the trip. I looked at the gears; cleaned off a lot of grease, could not see any pieces, but it sounded like metal on metal, grinding in the area of the winch; not in the motor.
so I yanked it off, called Goshen, ordered a new manual winch, and could not be happier. It is easy to use, not hard to crank the roof up and you are the upper limit switch; not a switch encased in grease.
So are they a problem? Mine sure were. I could understand one going bad; not happy, but could understand, but the replacement was a pain in the rear too.
I am not the only one who yanked off the power winch and replaced with a power unit.
f5moab is offline   Reply With Quote
Old 09-07-2015, 12:26 AM   #13
Cowboy6201's Avatar
I just bought a 2010 Rockwood HW296 3 weeks ago, I traded in a 2008 StarCraft Centennial 3612.
My next door neighbor owns Camping USA in E Bridgewater Ma, I had her take my StarCraft to replace the power supply which went bad. Tried putting up the roof with the power winch, which was also a the p55000, when she called Carefree they told her the same thing.
she called StarCraft, they $1000.00 for the winch.
She ended up buying the setup from power winch from Carefree for $720.00 it was a lot cheaper that way.
so now I traded that PUP for my 2010 Rockwood HW296, which has the same winch, I hope this one lasts.ni hope a replacement from Rockwood will be cheaper than StarCraft?
Cowboy6201 is offline   Reply With Quote
Old 09-07-2015, 07:01 AM   #14
Disasembling the motor
Originally Posted by CampingTerri View Post
Cessna,
I had to go back to my original post to remember this since it's been a while, and I'm still a little vague. However, the description in the original post which says to remove the long bolts holding the ends of the motor to the mid section would be the only mechanical thing to do. Mark those ends and mid section in order to put them back exactly after cleaning. The rest is just working with the unit to pull the shaft out. The worm gear is not removable nor replaceable on the shaft since it is welded. The shaft should pull out of the mid section in the direction of the worm gear, so removing it is not necessary. But those magnets do hold the shaft so pulling the shaft out seems like something else needs to be undone. Make sure the brushes are not binding and if the ends are off there should be no insurmountable problem. Wish I could be more help.
Old 09-12-2015, 06:55 AM   #15
You have a different style motor.
Trevor43 is offline   Reply With Quote
Old 06-15-2020, 03:07 PM   #16
Does anyone know if the backup 7/16" bolt head can be replaced if it's sheered off.
Micah is offline   Reply With Quote
electric, winch, winch motor, pop up, electrical
