Old 09-11-2015, 02:45 PM   #11
f5moab's Avatar
Originally Posted by kinma13 View Post
F5moab it should be the front corner of the roof. Between the canvas n roof fiberglass. I'll try and get a pic in a bit.
I was just making a statement since I wondered where the switch would be if there was no pull over sink/range like on my popup. NO photo needed. I was just always curious where the switch would be.
f5moab is offline   Reply With Quote
Old 09-11-2015, 09:50 PM   #12
OK, No switch located under sink in either top or bottom cabinet.
Confirmed NOTHING working on 12V, not even fridge. Battery OK.
Switch under inverter is solved: It's the pump switch.
Next step is pull of the panel in front of inverter and look for problems, I guess.
FireChief is offline   Reply With Quote
Old 09-11-2015, 11:37 PM   #13
bikendan's Avatar
As a retired firefighter/EMT, I just want to respectfully tell you, Chief, that it's a CONverter, not an INverter.
Never heard of any popup that didn't have some kind of inside kill switch.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 09-12-2015, 06:44 AM   #14
f5moab's Avatar
Does anything work when NOT plugged into shore power?
If NO, connect the trailer to shore power, and check voltage at the battery. The converter should start off at about 14 volts to the battery for a time, then drop. If the battery voltage at the battery is the same on shore power as when disconnected from shore power the battery is not connected to the converter.
This could be literally NOT connected, to the fuse being blown in the converter.
Check the 12 volt fuses in the converter.
Old 09-12-2015, 06:57 AM   #15
check the big orange fuses on the converter,one or both may be blown, something as simple as charging the battery externally can blow them.
because the unit uses the converter on shore power and converts it to 12 volt and that works i would say its gotta be a battery fuse issue.
on mine they are orange, here is an example
swimmarz is offline   Reply With Quote
pop up
