Old 11-19-2011, 06:42 AM   #1
popup power lift stopped working
I sure hope someone can help me with this...I have a 07 Forest River Flaggstaff pop up camper with a power lift. Needless to say, the it stopped working and now I can't get the top to go up or back down. I swapped out the battery but nothing happened. I ended up leaving it at the campground and went back home (only an hour away). I'm going back today to change out the fuse but if that doesnt work, I really don't know what else to do, anyone have any ideas??? Thanks in advance.
PS...If I cut the cable (last resort), will the top go down automatically?
roxsteven is offline   Reply With Quote
Old 11-19-2011, 06:49 AM   #2
grhodes50's Avatar
Check your manuals. There should be instructuons on how to raise/lower the top manually. There should be a tool similar to the one for your stabilzer jacks to do this.
I hope it's the fuse. That's an easier fix! Good luck!
Old 11-19-2011, 06:55 AM   #3
Thanks for your quick response, unfortunately I bought this trailer through an auction and it didnt come with any manuals. I have taken the cover off the power lift before to look for the manual override but I think the previous owners broke it off because it looks like it was sheared off. I really hope it's the fuse too. Thanks again!
Old 11-19-2011, 07:05 AM   #4
grhodes50's Avatar
Here's the instructions from my manual.
Pop-Up Motor.pdf
Hope this helps you.
Old 11-19-2011, 07:12 AM   #5
It does, I downloaded it several months ago and that 7/16' bolt for the manual override is missing. I really think its a power issue (fuse) because the last time the motor loosened up the motor made a loud clacking noise but this time there was nothing.
Old 11-19-2011, 07:23 AM   #6
grhodes50's Avatar
Check all of your wiring. I had that same problem once with the clicking noise and the cause was, gears had worn through the wiring insulation and the bare wire was touching the metal.
Old 11-19-2011, 07:26 AM   #7
will do, thanks again!
Old 11-21-2011, 03:28 PM   #8
daydreaming about camping
jeeplj8's Avatar
Are you sure? The hole should be full of greese. with all that greese packed I could not even see the bolt head down there.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 11-21-2011, 10:50 PM   #9
I'm sure, I've taken it apart this summer because the motor got loose and made a loud clacking noise. I had removed all of the grease just to make sure I wasn't missing something but there definitely isn't a 7/16 bolt there.
Old 11-23-2011, 09:38 AM   #10
jeeplj8's Avatar
wow - that bolt is actualy the top of the worm drive itself. If they sheared it off, I am shocked the system still works at all.
Hopefully your issue was electrical, and you got your camper down. However I would NOT use it again until replaced.
