Old 08-16-2014, 11:09 AM   #11
Kaadk's Avatar
Originally Posted by pman1088 View Post
This GFI has no buttons (like the rest in the trailer) just the one box on the wall by the rear side bed has buttons that shut down all the sockets in the whole trailer.
Oh, so then it's not a GFI, it's just a regular outlet.
The surest way to lose is to play Marco Polo with a ventriloquist.
Old 08-16-2014, 11:17 AM   #12
Premier 2514G Electrical Question
The outlet is probably for an option you do not have. If you check an options list you may be able to figure what would go there. The color of the Romex denotes the amperage,
White - #14 = 15 amp
Yellow - #12 = 20 amps
Orange - #10 = 30 amps
And it is correct that it is not a GFCI Outlet, it is a decora outlet
Started Out With Nothing,
Still Have Most Of It Left!
jwedell is offline   Reply With Quote
Old 08-25-2014, 07:28 PM   #13
We have the same thing on ours. It's for the roof mounted air conditioning. That is also what the extra black access door on the drivers side is for, to run the cord up to the AC unit. We plugged a power strip onto it and use it for charging the flashlights.
cousin_eddie is offline   Reply With Quote
Old 08-25-2014, 07:30 PM   #14
Another mystery solved.
2514g, electric, electrical
